I didn't see this problemRickky wrote:With this last version and C4D R19, all the shaders appears white in the viewport. A fix is on the road ? For the moment I install an older version
Cinema 4D version 4.05-R7 (V4 stable) 25.10.2019
Fixed build R4 is up! Most likely and hopefully latest build for V4 series.
with this one, the offset-problem with the render region is gone.
win7prof. | i7 4930, 32gb | 2*980ti 6g for renderings | 1*660 for displays
I haven't changed anythings for that. Probably it was a build issuemesut wrote:with this one, the offset-problem with the render region is gone.
Which version? I've removed AVX support in latest buildDimaS wrote:Hi, plugin not loading in c4d r21 (redshift version 2.6.47 working). Maybe problem with unsupporet AVX in cpu. system: cpu pentiumg3258, gpu 650 ti, win10
OctaneRender-for-C4D-V4.05-R4-win. On hackintosh working C4D-v4.05-R4 for c4d r21aoktar wrote:Which version? I've removed AVX support in latest buildDimaS wrote:Hi, plugin not loading in c4d r21 (redshift version 2.6.47 working). Maybe problem with unsupporet AVX in cpu. system: cpu pentiumg3258, gpu 650 ti, win10
- rezaansari
- Contact:
Hi aoktaraoktar wrote:Fixed build R4 is up! Most likely and hopefully latest build for V4 series.
It's very nice working on me
Thank you very much
It is working smoothly, Aoktar!
Thank you!
Thank you!
C4D 2025.3.3 Octane v1.9.4 // Octane SA 2026.4, Windows 11 Pro, X399, AMD TR 2950X, <<2 X 3090 + NVlink>>, 128 GB RAM, Corsair 1500i - NVIDIA SD 610.62
Octane User since V1 Beta
