Cinema 4D version 4.05-R7 (V4 stable) 25.10.2019
Hi All,
This is the latest stable release of the plugin which is based on V4.05 SDK and matches OctaneRender Standalone 4.05. To learn more about the new features and improvements of OctaneRender 4, please check out our blog post.
License upgrade
Unless you have a subscription license, you will have to upgrade your version 3 licenses to version 4. This upgrade is free and can be done via these 4 steps:
Go to https://home.otoy.com/render/octane-render/purchase/
Select "Upgrade" in the top menu.
Click on "UPGRADE NOW" next to "Upgrade existing licenses to OctaneRender 4".
Select the licenses you want to upgrade and confirm.
To use this version, you need a GPU of compute model 3.0 or higher. Support for Fermi GPUs (like GTX 4xx and 5xx) has been dropped. Also make sure you use a driver of version 387 or higher and if you are working on Mac OS that have a CUDA driver installed that supports at least CUDA 9.1.
1- Try different drivers, some of them could cause instability issues. Do a clean install while doing this to be sure previous files completely removed.
2- Check gpu frequency. Overclocking would cause instability issues
4- Check the free amount of GPU's VRAM and system's RAM while working. Low VRAM will/may cause CUDA errors. Be aware of some generator objects will have different triangle count in Picture Viewer than Live Viewer. It’s like “editor/render” parameter. Just try to use same value. Also try to optimise your scene for polygon count, even use smaller images. Try to use Octane texture nodes rather than using C4D texture/shaders.
5- If you see C4D crashes without CUDA errors, then send us bugreport.zip, screen-shots and video capture to show process and crash moment. Also please send us a sample scene in a format of C4D or ORBX to let us investigate and test it. Alternatively, try to delete/hide some objects/materials until crash gone away. If you find what's causing crashes, send us a sample scene to let us for
investigating and bring a fix or solution.
Thanks for helping the development by your feedbackst! It’s impossible to quickly catch every case without user feedbacks! It’s the same procedure as other companies do like Maxon/etc...
Changes of 4.05-R7
- fix: broken download of old blend materials
Changes of 4.05-R6
- Keeping node attributes in localdb materials.
- Fix: Hang issue in quit phase after some specific operation
- Fix of some missing livedb material convert functionalites
- Missing transmission type in universal material
- Fix: (De)select all passes button
- Added: Motionblur support on splines with ObjectTag->Hair render
- Fix: update issue for R21 material previews due to changes of R21 SDK
Changes of 4.05-R4
- A few minor fixes for issues of previous build
Changes of 4.05-R3
- Fixed the issues of R21 version
- Node editor fixes
Changes of 4.05-R2
- Fix: Ignored "normalize" parameter of Octane Light tag
- Fix: Performance issue on Volume object when use empty filename
- Improved material/tag/object import/update on Node Editor
Changes of V4.05
- Fix: max value=254 for render_layer_mask pixels with PNG
- Added OslBaking Camera
- Improved Node Editor support for Octane objects and Octane tags
- Small change on InstanceColor
- Fixed: missing round_edges parameter and removed cutoff from post effects
Standalone 4.05
viewtopic.php?f=24&t=71916
Important warning: Do not post any screen shots from R21 until it releases officially.
WINDOWS REGULAR BUILD (R15-R21)
https://render.otoy.com/customerdownloa ... R7-win.rar
WINDOWS SUBSCRIPTION(Studio) BUILD (R15-R21)
OSX REGULAR BUILD (R15-R21)
https://render.otoy.com/customerdownloa ... Macosx.zip
OSX SUBSCRIPTION(Studio) BUILD (R15-R21)
RES file for R15
res.zip
(18.24 MiB) Downloaded 611 times
Requirements:
-You'll need to update your Cinema 4D to latest versions(min. R16.050, R17.053, R18.057, R19.053, R20.057)
-Internet connection for activation, be sure that C4D and Octane will not be blocked by firewall and any antivirus software.
-Updated Nvidia drivers at least 388.xx, recommended 417.22 or 419.17 (one of most recent with Cuda 9.1) and be carreful with latest drivers which can cause cuda errors. Avoids to use 418.81.
-Cuda 9.1 driver for OSX.
ONLINE HELP MANUAL
To use OFFLINE version of manual from plugin
Download following package and extract to Cinema4D/plugins/c4doctane/manual
https://render.otoy.com/plugindownloads ... 4-help.rar
V3 SAMPLE SCENES SET(make a request if you need any spesific sample)
https://render.otoy.com/plugindownloads ... scenes.rar
resource file for R15. Extract and replace old "c4doctane/res" directory with this.
The attachment res.rar is no longer available
See this topic for some partial samples: viewtopic.php?f=85&t=53989
CINEMA 4D TUTORIALS SECTION: viewforum.php?f=87
CHANGE LOG: https://docs.otoy.com/#60Change%20log
Installation
First remove all octane related stuff from plugins and main folder of Cinema4D.
Also download manual.zip and extract to c4dOctane directory if it's not available in place.
Ex. if you have Cinema4D R18.0, keep only "c4dOctane-r18.cdl64" and delete c4dOctane-r17.cdl64, c4dOctane-r16.cdl64, c4dOctane-r15.cdl64, etc..
Cinema 4D Release 15: c4dOctane-r15.cdl64 or c4doctane_R15_demo.dylib
Cinema 4D Release 16: c4dOctane-r16.cdl64 or c4doctane_R16_demo.dylib
Cinema 4D Release 17: c4dOctane-r17.cdl64 or c4doctane_R17_demo.dylib
Cinema 4D Release 18: c4dOctane-r18.cdl64 or c4doctane_R18_demo.dylib
Cinema 4D Release 19: c4dOctane-r19.cdl64 or c4doctane_R19_demo.dylib
Cinema 4D Release 20: c4dOctane-r20.xdl64 or c4doctane_R20_demo.xlib
ORBX EXAMPLE VIDEO
https://vimeo.com/302046063
Node sliders
https://vimeo.com/268974364
Viewport rendering mode
https://vimeo.com/265747658
https://vimeo.com/265294205
thanulee
Thanks buddy!
artdude12
Thanks for the update!
i7 4930K_Asus_RampageIV-Extreme_64GB_3-Titan_NVIDIA-337.88_Win7-64
fractaledvisions
Cinema4D R20 won't open after I installed this. Just hangs at 5% CPU usage in the task manager and never opens. Was hoping this would fix endless crashes on 4.04. Guess not.
ch0pper
yep not working for me also
W7 64 bit |I7-3970X | GTX 780 X2(6GB) GTX 780TI X2 | 64 GB DDR3 RAM
Real Skin & real hair for Poser / DAZ Studio OctaneRender/iray - coming soon
thanulee
Heya, W coordinate doesnt work with bump channel ?
I render c4d hair via an octane tag and from there i try use W coordinate node for bump. It works in any other channel but bump. Was that always the case? thanks
fractaledvisions wrote:Cinema4D R20 won't open after I installed this. Just hangs at 5% CPU usage in the task manager and never opens. Was hoping this would fix endless crashes on 4.04. Guess not.
Could you please give information about your crashes? Cuda errors you mean or plugin crashes? Put bugreport.zip please.
thanulee wrote:Heya, W coordinate doesnt work with bump channel ?
Could you please share a sample scene?
Have you deleted other versions of plugin dlls? There's R21 build and keeps locking the R20 plugin if you keep it.
thanulee
here is is: https://www.dropbox.com/s/tqwciqszjbf6c ... p.c4d?dl=0
ty
