Cinema 4D version 4.05-R7 (V4 stable) 25.10.2019
Rickky wrote:With this last version and C4D R19, all the shaders appears white in the viewport. A fix is on the road ? For the moment I install an older version
I didn't see this problem
Rickky
Hello Aoktar
This is a screen capture of the problem
Best regards
Fixed build R4 is up! Most likely and hopefully latest build for V4 series.
mesut
with this one, the offset-problem with the render region is gone.
win7prof. | i7 4930, 32gb | 2*980ti 6g for renderings | 1*660 for displays
mesut wrote:with this one, the offset-problem with the render region is gone.
I haven't changed anythings for that. Probably it was a build issue
DimaS
Hi, plugin not loading in c4d r21 (redshift version 2.6.47 working). Maybe problem with unsupporet AVX in cpu. system: cpu pentiumg3258, gpu 650 ti, win10
DimaS wrote:Hi, plugin not loading in c4d r21 (redshift version 2.6.47 working). Maybe problem with unsupporet AVX in cpu. system: cpu pentiumg3258, gpu 650 ti, win10
Which version? I've removed AVX support in latest build
DimaS
OctaneRender-for-C4D-V4.05-R4-win. On hackintosh working C4D-v4.05-R4 for c4d r21
rezaansari
aoktar wrote:Fixed build R4 is up! Most likely and hopefully latest build for V4 series.
Hi aoktar
It's very nice working on me
Thank you very much
Kalua
It is working smoothly, Aoktar!
Thank you!
Octane User since V1 Beta
Return to “Releases”
