yes for the 2.0
So i just put a normal octane material on the hair object on top of the c4d hair material?
Octane Render 2.0 for Cinema 4D previews
Heelie wrote:yes for the 2.0
As in picture. This package has a few samples:
http://render.otoy.com/customerdownload ... amples.zip
- Attachments
- 2014-06-13_014813.jpg (18.3 KiB) Viewed 13809 times
- stefan_laub
it seems i had an too old cuda. i assume the update to 6.0 will solve it, (i will do that as soon i have some time)
thanks
Stefan
thanks
Stefan
aoktar wrote:stefan?stefan_laub wrote:so wanted to try new version.
what do i make wrong if it renders only black?
license is updated,and status of octane and c4d plugin ok
added daylight also
it seems to refuse to render yet
Stefan
edit:ok think cuda drivers have an issue yet. i try reinstall
can you check the gpu devices on Settings Window? If there is no device, this shows a driver problem or gpu is not compatible.
Stefan,stefan_laub wrote:it seems i had an too old cuda. i assume the update to 6.0 will solve it, (i will do that as soon i have some time)
thanks
Stefan
are you the guy of vrayc4d? Is right?
- stefan_laub
yes:)
congratulations to your c4d plugin by the way
stefan
stefan
aoktar wrote:Stefan,stefan_laub wrote:it seems i had an too old cuda. i assume the update to 6.0 will solve it, (i will do that as soon i have some time)
thanks
Stefan
Thanks Stefan!stefan_laub wrote:yes:)
stefan
Ahmet Oktar
- sparkworld
Do you notice your cards run much slower on your macs than your PC's? We're in the experimental phase and while overjoyed at what octane is doing we're not crazy about the speed of the Nvidia cards on the Macs. Any thoughts? Thanks.
Tony
Tony
What cards are you using, and what benchmarks are you getting? I only have a 680 Mac Edition and a GTX 570 at the moment (I have a Netstor enclosure which I'll populate with 780Tis) - the latter runs the benchmark scene faster under 2.0.
Also, are you using the latest OS X and/or Nvidia drivers?
Octane render v02 test : https://vimeo.com/98623570
