Octane Render 2.0 for Cinema 4D previews
Sub forum for help and tutorials.
Heelie
yes for the 2.0
So i just put a normal octane material on the hair object on top of the c4d hair material?
Heelie wrote:yes for the 2.0
As in picture. This package has a few samples:
http://render.otoy.com/customerdownload ... amples.zip
stefan_laub
it seems i had an too old cuda. i assume the update to 6.0 will solve it, (i will do that as soon i have some time)
thanks
Stefan
aoktar wrote:
stefan_laub wrote:so wanted to try new version.
what do i make wrong if it renders only black?
license is updated,and status of octane and c4d plugin ok
added daylight also
it seems to refuse to render yet
Stefan
edit:ok think cuda drivers have an issue yet. i try reinstall
stefan?
can you check the gpu devices on Settings Window? If there is no device, this shows a driver problem or gpu is not compatible.
stefan_laub wrote:it seems i had an too old cuda. i assume the update to 6.0 will solve it, (i will do that as soon i have some time)
thanks
Stefan
Stefan,
are you the guy of vrayc4d? Is right?
zackyd
two of my favorite developers in one forum :)
4x GTX 780 6gb // 32gb ram // 1600w
stefan_laub
yes:)
congratulations to your c4d plugin by the way
stefan
thanks
Stefan
Stefan,
stefan_laub wrote:yes:)
stefan
Thanks Stefan!
Cheers,
Ahmet Oktar
sparkworld
Do you notice your cards run much slower on your macs than your PC's? We're in the experimental phase and while overjoyed at what octane is doing we're not crazy about the speed of the Nvidia cards on the Macs. Any thoughts? Thanks.
Tony
Weezer
What cards are you using, and what benchmarks are you getting? I only have a 680 Mac Edition and a GTX 570 at the moment (I have a Netstor enclosure which I'll populate with 780Tis) - the latter runs the benchmark scene faster under 2.0.
Also, are you using the latest OS X and/or Nvidia drivers?
bphoton
Octane render v02 test : https://vimeo.com/98623570
Return to “Help / Tutorials”
