OctaneRender® pre-Beta 2.3 v5 (win/lin/mac) [OBSOLETE]
vanlicht
bepeg4d wrote:
there is a workaround for this:
http://www.refractivesoftware.com/forum ... f=9&t=3748
Cool, thanks for the link Beppe, it solved the material problem, the chance of crash reduces much, and the materials do stick to the scene.
Thomas
Windows 7 64bit | Maya 2010 64 bit (main) | Maya 2011 | Intel i7-920 | Nvidia Quadro FX1800 | Nvidia GTX480
face
Have anyone tested the camera MB?
It seems it doesn´t work.
The parameters from the plugin are exported correct.
It would be nice when somebody can confirm that...
face
http://vimeo.com/user2509578
face
I have test the motion blur and it doesn´t work in all pre2.3 versions.
Pre2.3 & 2.3v2 crash, pre2.3v3-v5 don´t render it.
face
[vimeo]http://www.vimeo.com/16997705[/vimeo]
re0dor
Does anyone else also have problems rendering images in high resolution?
In scenes with some complex geometry and specular/glossy materials, Octane crashes
when I change to finalrender resolution(approx 4000x3000), or it renders a wrong resolution(ex.:4000x600)
I'm working an a project now, where going above 1400x2000 induces crash. Videocard memory usage is not even half of potential.
Getting messages that the Nvidia driver has crashed and that its been restored.Mostly problems
occure with pathtracing, but also with directlighting.
Any Ideas, anyone..?
Windows 7 pro|Asus p5e3 ws pro|Q6600, 2,4Ghz|OZC 8Gb ram|Corsair 120Gb SSD|dual EVGA GTX470|Nvidia 260.99|cuda 3.0|octane 2.43
andrian
Hi re0dor. You might wanna read about this old issue here: http://www.refractivesoftware.com/forum ... f=21&t=824
or, just install, without activating the beta 2.2 witch will do the registry hack for you automatically..
reboot the PC after that...
Vista 64 , 2x Xeon 5440 - 24GB RAM, 1x GTX 260 & I7 3930 water cooled - 32GB RAM, 1 x GTX 480+ 1x8800 GTS 512
CGsociety gallery
My portfolio
My portfolio2 - under construction
Web site
Making of : pool scene - part1
re0dor
That did the trick. Thanks!
abstrax
face wrote:I have test the motion blur and it doesn´t work in all pre2.3 versions.
face
Thanks for the heads up. The upcoming release will have a fix and motion blur should work again.
Marcus
face
Have found another strange thing, maybe someone has report it.
Looks like a scaling issue, but an import in Modo shows me the correct size.
If I make a 1m cube and use a specular material, then i become a circle as transmission.
I can change the size of the circle with an other IOR value.
EDIT:
It comes at a maxdepth/speculardepth of 3
face
radiance
face wrote:Have found another strange thing, maybe someone has report it.
EDIT:
face
I think this is just normal internal reflection.
Does it also present with pathtracing at a propper maxdepth like something > 10 ?
Radiance
face
Yes, it´s ever present. As long as the depth value is over 2...
Has seen the same effect with 1.022.
If the IOR is > 1.4 the angle to see it, is to sharp.
Maybe youre right and its a normal reflection.
face
