OctaneRender® pre-Beta 2.3 v5 (win/lin/mac) [OBSOLETE]
radiance
Hi everyone,
Refractive Software® is proud to announce the availability of the fifth intermediate octanelive® testing release. (aka pre-2.3 v5)
This release is for PC's running MS Windows (x64), linux (x64) and Mac OS X (32). An MS Windows build for 32 bit will follow on monday.
This release is therefore recommended to be used for any professional applications where time is crucial, use at your own risk. For critical work, please use 2.2b stable.
Please note also this version will need you to enter your OctaneLive® account and password. These can be found as explained here:
http://www.refractivesoftware.com/forum ... =24&t=3095
New Features and fixes since pre-2.3 v4
Here is a little example with images and tutorial on how to use the new firefly removal feature effectively here:
http://www.refractivesoftware.com/forum ... =21&t=3766
The next v6 release will include the new render algorithm we've developed and will make the firefly removal system obsolete, but it might still be handy for certain situations.
- Documentation: A brand new PDF manual, completely redesigned from scratch, over 120 pages, with widescreen layout, and easy chapters/bookmark links (please use with acrobat reader)
- Hotpixel/Firefly removal for the imager, to get rid of fireflies in real-time when tonemapping/rendering with a sensitivity slider. (it's a new slider in the camera tonemapper options)
- Roughness option for specular materials, to render rough/glossy glass, like a sanded or milky looking glass.
- Mix material to blend between two materials.
- Improvements to glossy material, to solve dark edges (energy loss) problem.
- Improvements for emitters to reduce noise when nearby other surfaces.
- Many more improvements to increase convergence with less noise hotpixels/fireflies. (eg, the image noise clears up faster)
- Stability fixes for drag & drop from the outliner.
- Stability fixes for working with multiple GPU's.
- Fix incorrect sun position in daylight environment.
- Fix crash when trying to override object import preferences.
- Fix multiplier key not working.
- Fix original zoom direction for zoom with the mouse wheel.
- Fix images embed when saving file that uses macros with embedded texture.
- Fix a problem loading .ocs with saved material macro and texture.
- Fix a problem saving .ocs with embedded images.
- Fix duplicate nodes being created when loading object with nodes connect to material.
- Fix problem where unitinialized macro's could be created.
[/b]How to connect to OctaneLive® through a firewall/router[/b]
If you have a firewall/router, and you cannot log into the octanelive® service (eg, the server cannot be contacted), configure your firewall or router to allow outbound connections to the URL named 'live1.refractivesoftware.com'.
No new drivers are needed for this release, it uses the same drivers/toolkits as the previous pre Beta 2.3 v4 release
Download
MS Windows
ZIP file archives:
32bit: http://www.refractivesoftware.com/rcdow ... _win32.zip ( 33 MB)
64bit: http://www.refractivesoftware.com/rcdow ... in_x64.zip ( 35 MB)
GNU/Linux
gzipped/tar archives:
64bit: http://www.refractivesoftware.com/rcdow ... ux_x64.tgz ( 36 MB)
Apple Mac OS X (10.5/6)
Installer package:
32bit: http://www.refractivesoftware.com/rcdow ... s_x_32.pkg ( 38 MB)
Please post your experiences and issues with this release in this thread.
Your help is much appreciated.
Yours,
The OctaneRender® Team.
face
mmmh nice...
Good work, thanks again, downloading and testing ;)
face
http://vimeo.com/user2509578
Elvissuperstar007
Zay
Can it be true that it's almost a full megasampel per sec slower than 1.22beta? (Using the benchmark scene in pathtracing). From 3.06 to 2.33
I thought v5 would have the options to manually scale OBJ files on import? I really really need this to test things as I have many "bugs" untill this is supported.
Win 11 Pro | i5 12600K | 32GB ram | 2x GTX 1080Ti + 3080Ti - studio driver 560.94| Modo/Blender/ZBrush/Daz/Poser
intelligentlight
Great news, thanks!
Lead 3D Artist/Photographer, Sweden
Work: AMD Ryzen 9 5950X, 2 x ASUS ROG RTX3090, 128 Gb RAM
Home: AMD Ryzen 9 3900X, 1 x ASUS ROG RTX3070, 64 Gb RAM
Octane Render since 2012 <3
chilehabanero
thanks!!
radiant
i was wondering why so many people were on here, i then look here and then bam a new release lol
EDIT: dam im capped from downloading sintel :/
Looks like i cant touch this baby till i get some bandwidth
Win8 Pro 64bit ULT|Intel Core i7 3930K|3.20 GHz|32 GB RAM|GTX 590|UD5 2011 socket||2x TB HD||Master Cooler HAF X||Blender 2.6||Maya 2012||Octane|
Synthercat
Minor bug (also on v4)
Fire up Octane v5
add specular material
change direct to path
click on material to make it show on preview and on node inspector
turn opacity all the way to 0
seems nice... but
Change texture environment to daylight and see that the kind-of-star-shaper-material-hole is still visible
Linux Mint 19.3 | GTX-1080Ti | AMD FX-8320 (OCed 4.4GHz) | 16GB RAM
lixai
still a ton of firefly
can't use this
Core i7 860, ZOTAC GTX 580 - 3GB, 2 x GTX TITAN, 32Gb RAM
oguzbir
This iz tha best versn. Woow. Thumbs up folks.
Now go to a nearest bar.
Chill...
I
My Portfolio
