OctaneRender® 1.0 beta2.52 >>> download here <<< [OBSOLETE]
t_3
Refracty wrote:So is it a common problem that the computer crashes completely (reboot)?
Before, I only made the experience that the Octane application thread was hanging.
I am taking into account that my PSU has fail funtions but I am not sure. I will investigate more...
Thanks.
i'd say that (at least under win 7 x64) a total crash is 99.9% hardware related. other things that may cause such a behaviour are almost ever driver related (maybe check with another nvidia driver version?), because of their low-level access to the system. even real bad application crashes are normally "only" freezes.
you may also check the condensers on the motherboard, because - depending on their quality - the might wear off and die some time (yet accelerated by constant high temperatures and high loads)... what then could cause critical voltage ripples under load.
Elvissuperstar007
t_3
Elvissuperstar007 wrote:http://www.refractivesoftware.com/forum/viewtopic.php?f=33&t=8701
i think your problems are completely different - have posted my thoughts there...
SamCameron
Hey mates, you really need to sort out the problem of rendering animations and gets stops, I'm trying even the version 2.51 with the same problem, we just lost several days of rendering because we go to sleep and when we wake up we see that the render stoped 1 hour after we went to be, so the whole night process is lost, this is really a pain in the ass, hope you publish a new version soon with this fix, thanks.
face
SamCameron wrote:Hey mates, you really need to sort out the problem of rendering animations and gets stops, I'm trying even the version 2.51 with the same problem, we just lost several days of rendering because we go to sleep and when we wake up we see that the render stoped 1 hour after we went to be, so the whole night process is lost, this is really a pain in the ass, hope you publish a new version soon with this fix, thanks.
Maybe a little help...
http://refractivesoftware.com/forum/vie ... =29&t=8776
face
http://vimeo.com/user2509578
Refracty
Thanks for the tips.
So I have figuered out that the problems happen mostly with PMC.
Could that point to a driver error issue?
Don't you think that it could be a PSU error?
I will install a different NVIDIA driver tomorrow.
SamCameron
the problem persists in different machines with differents versions and operating systems, but the problem remains in every machine we have in here.
Valiant
Thanks a lot for the update. Where can I see the cuda link for this release? I checked preferences and it says 0 driver cuda installed, maybe that's the reason why I can't see anything in the preview/viewport? I tried to at least click the live db samples/materials and they look great but still i can't see anything in the preview/viewport.
Window7.X64 l Corei7 2600K 3.4MHz OC 4.5MHz l Asus P8P67 Deluxe B3 l 16GB DDR3 Corsair Vengeance 1600MHz l 1.5GB EVGA GTX580 SC FTW l 240GB OCZ Vertex2 SSD + 1GB WD Caviar Green + 1GB WD Caviar Green l 1200Watts Corsair AX1200 l HAFX l Corsair H70
matej
Normalmapping doesn't work if the texture is piped through a texture input pin into the material macro. The texture must be inside the macro, for normalmapping to work:
cgmo.net
roeland
Valiant wrote:Thanks a lot for the update. Where can I see the cuda link for this release? I checked preferences and it says 0 driver cuda installed, maybe that's the reason why I can't see anything in the preview/viewport? I tried to at least click the live db samples/materials and they look great but still i can't see anything in the preview/viewport.
You don't need a separate CUDA download, only the nvidia driver.
Roeland
