Test Version 3.07-Test3a
thanulee
Ye sorry i figured it out after i posted here.
mrwig
I'm getting some weird render results with this version while using network rendering.
I just read about the fog medium issue with OctaneSky objects, and I was using a medium, could this result be due to that?
I just ran a test render without the sky medium and the checkering effect disappeared.
I've attached an image of the weird result I got while the sky medium was active:
Multimedia Designer
ASUS Rampage V Edition 10, Intel 5960x @ 4.2GHz, 3x nVidia GTX1080, 64MB 3000 Corsair Dominator, Win 7
Intel 7800x, 16GB Ram, 2x nVidia GTX 1080, Win 7 (Netrender)
VVG
mrwig wrote:I've attached an image of the weird result I got while the sky medium was active:
read on the previous page. it`s bug 3.07 test SDK
Win 10x64, AMD 1950x 16C/32T, RAM 32Gb, RTX 3060x3
Octane-for-C4D(R23.110)2021.x.x, Cycles4D, Centileo. Nvidia 472.47 STUDIO
I'm preparing test6 release. It will be available soon
bartolos
Please fix.
globodigital
Hello! I'm a new user, I currently have Cinema 4D R19.008 installed and when I install the new 3.07-Test3a plugin it's menus do not show up in Cinema.
I've made sure to delete all .cdl64 files except "c4dOctane-r19.cdl64" and have also installed the same build of the Octane standalone renderer.
What am I doing wrong?
Hi globodigital,
you need to update your c4d to R19.024, and install the new stable 3.07-R1, instead of the test version:
viewtopic.php?f=85&t=63700
Happy GPU Rendering,
ramiz
I've tried the test builds and the stable releases but still can't get 3.07 to work in R19.
If I leave the R18 file in the plugin folder I can see the Octane menu item but none of the submenu options.
I've also tried placing the plugin in the Users>AppData Path for C4D Preferences and the Regular Program Files path but still no avail...
Any help?
Hi ramiz,
instead of moving the c4doctane folder in the wrong place, you only need to update your Maxon c4d to R19.024, as written everywhere, even in the previous post.
And please, install the latest version v3.07-R2:
viewtopic.php?f=85&t=63700#p324859
