OctaneRender® 2026.1
akvahouse
Hi guys, Gaussian splats is broken in this release?
Same file works fine in houdini
Win 11 x64 | Amd threadripper 1950x | 128gb | Rtx 3090ti
mojave
akvahouse wrote: Tue Dec 02, 2025 10:51 pm Hi guys, Gaussian splats is broken in this release?
Looks like the file path has a ":" at the end? If this is not the issue, could you share a link to the file itself?
akvahouse
mojave wrote: Tue Dec 02, 2025 11:08 pm
All three files I found online do not work in Octane. Perhaps there are some special settings that need to be enabled for them to work properly.
Link to splats:
https://fex.net/s/tldnb6d
jobigoud
akvahouse wrote: Wed Dec 03, 2025 8:52 am All three files I found online do not work in Octane. Perhaps there are some special settings that need to be enabled for them to work properly.
These appear to be regular point cloud PLY files, not gaussian splats.
Some viewers might detect that and load them as regular point clouds like Houdini but Octane gaussian splat node currently doesn't handle that. Many other GS viewers will fail in the same way.
The error message we show when this happens could be improved. The colon at the end of the path is unrelated.
nuno1980
Happy holidays! :)
VRAM size used at PT@32-parallel and @128-tile:
--at 7680x4320
2026.1 - 10.3GB
2025.x - 2.6GB
--at 1920x1080
2026.1 - 2.8GB
2025.x - 2.6GB
Why does new 2026.1 need to use VRAM size for resolution screen? But 2026.1 seems to be "not" faster than 2025.x.
PT vs PHT kernels - spp nrs
Caustics at PT
i7-12700KF
32GB DDR4@3600
GF RTX 4090 <3 :mrgreen:
NEW ACER Predator XB273U F5 27" :D
mojave
nuno1980 wrote: Sun Dec 07, 2025 11:07 am Happy holidays! :)
--at 7680x4320
2026.1 - 10.3GB
2025.x - 2.6GB
--at 1920x1080
2026.1 - 2.8GB
2025.x - 2.6GB
Thank you for the report, we will look into this.
tombyrom
Hello guys,
The new displacement is completely broken when used in conjunction with a normal or bump map. Please see attached. It completely breaks the UV's
Please can this be looked at?
For landscapes, using mix material this will be super important, and means we will need to use the old displacement
It is also pretty much broken on any mesh with a high poly count
Tugpsx
Having an issue alembic import whereas the batch render does not match the viewport. I understand that I can adjust the images in post, but something may be off with the batch render, or I have something incorrectly set. Here is my batch setting.
J.C
tombyrom wrote: Mon Dec 08, 2025 10:38 pm Hello guys,
The triangles (number depend on mesh triangles count) appear on any mesh. Looks like a bug to fix.
System – Windows 11
coilbook
So is neural rendering a replacement for Brigade?
