I updated Houdini and after several attempts, it finally worked ! Honestly, I'm not sure Houdini's version was the issue and I'm pretty certain I had released all slaves before rendering...
Anyway, thanks a lot for your time !!
PDG batch render network slaves not available
- Barry Convex
Win7 64 - Linux Mint 16 | Gigabyte Gtx760 4gb | Intel i7 3930k | 24gb Ram
Thank you for reply, Juanjgon.
I am trying to render multiple settings out of my scene using PDG, each setting have only 1 frame.
I tried to speed up the processing time by increasing Slots Per Works Item to make it run multiple renders at the same time.
But it will show up an Authentication window says 'Another instance is currently performing authentication tasks'.
I tried disable network rendering using Textport. Didn't work.
And I can't turn off network rendering from ROP because I am using a rental license.
I am using Octane 2020.3.0 and Houdini 18.5.532
How do I prevent this message coming out?
Thank you very much!
