Octane crashes
Idonee
Aoktar, can you please help us? Or tell me what to fix in our systems in order to get rid of crashes. On the advice above, I updated Windows, but nothing has changed for me, the crashes are the same. Any idea what might be causing this?
jeremyshin
Idonee wrote:Aoktar, can you please help us? Or tell me what to fix in our systems in order to get rid of crashes. On the advice above, I updated Windows, but nothing has changed for me, the crashes are the same. Any idea what might be causing this?
Try this :
C:\Users\username\AppData\Local\OctaneRender\cache > delete the folder "texCache" > restart C4D and test a render.
I cannot know because I don't see about my side, seems like a core issue. If you cannot solve it talk with support, beppe or helpdesk
Idonee
Try this :
bless you, it works. Interesting what is the core problem but i can just clear folder when get crushed, fine for temp solution, thank you.
One idea,
Are you using texture compressions? Error messages and texCache are up to the compression feature.
Idonee
when i clear cache folder - all works fine most of time, (and i had to turn off texture caching). But there is some bugs left, for ex. native gradient cinema 4d in any node - instacrash octane.
