Cinema 4D version 2020.1-XB2-R2 (EXPERIMENTAL) 10.01.2020
pxlntwrk wrote:Hi,
Happy New Year, and thanks for new release!
it's really cool to finally be able to use non-baked native c4d noise :D
Thanks! I wish happy new year to all of you!
m2001
aoktar wrote:
m2001 wrote:
Update:
- PC reboot
- new download 2020.1-XB2
- c4d start > hangs
-> windows taskmanager > c4d with 7-8% CPU (waited 2 minutes)
- back to 2020.1-XB1-Test2 > works
Check you installation for double install
Sorry, may be my fault, but I don't know where the problem can arise. I recorded it:
- started with 2020.1-XB1-Test2 (EXPERIMENTAL) 10.12.2019
-> works
- exchange > 2020.1-XB2 (EXPERIMENTAL) 01.01.2020
-> hangs
- back
-> works
Does "double install" mean that there are in the / plugins / folder 2 Octane Folder?
Thanks for your Help!
to know exactly which version is installed, please go to c4d menu Script/Console or Extensions/Console, (Shift+F10), and check the first lines.
The Live View title could be misleading.
ciao Beppe
bepeg4d wrote:Hi,
ciao Beppe
better to take a look to c4doctanelog.txt
m2001
aoktar wrote:
bepeg4d wrote:Hi,
ciao Beppe
c4doctanelog - startet with XB1
- c4d start ok
[2020-01-02 12:04:45][1] Register OctaneLive
[2020-01-02 12:04:45][0] Loaded Octane DLL:OctaneRender Enterprise 2020.1 XB1  version:8000000  SDK:2020.1 XB1
[2020-01-02 12:04:45][0] Octane Render for Cinema 4D 2020.1_XB1-test2  built for:200   C4D vers:20059
[2020-01-02 12:04:45][0] C4D:20059  comp:[RECHNER]  OS:[WINDOWS 64 BIT] Windows 10, 64 Bit, Core (build 18363)  opengl:460  sysInfo:32  versType:2
[2020-01-02 12:04:45][0] CPU:[GenuineIntel, stepping 4, model 5, instruction family 6]  speed:3.6 GHz  numOfCpu:16Ht
[2020-01-02 12:04:45][0] Plugins:[houdiniconfig addons advanced render alembic archigrass bitmapfilter bpexchange browser c4d_bridge c4dOctane-R20 ca ca2 cadexchange clothilde collada14 collada15 colorchoosergui compositing dwg dwgobjects dynamics exchanges expressiontag fbx gpurenderer hair hot4dr20 i_skp iges io_obj licenseserver metrics mkmodeler mocca model mograph motioncam motiontracker nbp newman nodeeditor objects onlinehelp onlineupdater python relaxuv sculpt sculptbrushes shader sketch sky sla spacemouse substance teamrender texturemanager thinking particles tpoperators volumes walkthrough X-Particles xpressocore xtensions ]
[2020-01-02 12:04:45][1] LoadOslScripts()
[2020-01-02 12:04:45][0] Loaded 85 osl scripts from dir:C:\Program Files\MAXON\CINEMA 4D R20\plugins\c4doctane\res\osl_scripts
[2020-01-02 12:04:45][1] LoadCustomLuts()
[2020-01-02 12:05:27][1] <markMaterials>
[2020-01-02 12:05:28][1] RestoreLayout(secret=c68fc1e8)
[2020-01-02 12:05:28][1] InitFromRestoreLayout
[2020-01-02 12:05:28][1] setResFromRndSettings 0x000001B9CD61CD80 [OK]
[2020-01-02 12:05:28][1] initOctaneLive()
[2020-01-02 12:05:28][1] Init OctaneLive...[2020-01-02 12:05:29][1] Plugin initialized.[2020-01-02 12:05:29][1] Plugin activation...[2020-01-02 12:05:33][1] Plugin activation OK.[2020-01-02 12:05:33][1] Activation time=5.275 sec.
[2020-01-02 12:05:33][1] readDeviceActivity  Dev0:E Dev1:E
[2020-01-02 12:05:33][1] readDevicePriority  Dev0:TN Dev1:T
[2020-01-02 12:05:33][0] VRAM used/free/max:0Kb/11Gb/11Gb  Out-of-core used:0Kb  RAM used:6.813Gb total:31.7Gb  OpenGL free/total:0/0
[2020-01-02 12:05:33][1] Device:0  [GeForce GTX 1080 Ti]<Dis>[][6.1]  Memory used/free/total:0Kb/11Gb/11Gb  outOfCoreMem:0Kb  p2pBytesUsed:0  runtimeDataSize:0Kb temperature:39
[2020-01-02 12:05:33][1] Device:1  [GeForce GTX 1080 Ti]<Dis>[][6.1]  Memory used/free/total:0Kb/11Gb/11Gb  outOfCoreMem:0Kb  p2pBytesUsed:0  runtimeDataSize:0Kb temperature:44
[2020-01-02 12:05:33][1]  readPrmsFrScn(1)
[2020-01-02 12:05:33][1] readPrmsBC 11111
c4doctanelog - startet with XB2
- c4d start hangs
- last entry "LoadCustomLuts()"
[2020-01-02 12:08:39][1] Register OctaneLive
[2020-01-02 12:08:39][0] Loaded Octane DLL:OctaneRender Enterprise 2020.1 XB2  version:8000001  SDK:2020.1 XB2
[2020-01-02 12:08:39][0] Octane Render for Cinema 4D 2020.1_XB1-test2  built for:200   C4D vers:20059
[2020-01-02 12:08:39][0] C4D:20059  comp:[RECHNER]  OS:[WINDOWS 64 BIT] Windows 10, 64 Bit, Core (build 18363)  opengl:460  sysInfo:32  versType:2
[2020-01-02 12:08:39][0] CPU:[GenuineIntel, stepping 4, model 5, instruction family 6]  speed:3.6 GHz  numOfCpu:16Ht
[2020-01-02 12:08:39][0] Plugins:[houdiniconfig addons advanced render alembic archigrass bitmapfilter bpexchange browser c4d_bridge c4dOctane-R20 ca ca2 cadexchange clothilde collada14 collada15 colorchoosergui compositing dwg dwgobjects dynamics exchanges expressiontag fbx gpurenderer hair hot4dr20 i_skp iges io_obj licenseserver metrics mkmodeler mocca model mograph motioncam motiontracker nbp newman nodeeditor objects onlinehelp onlineupdater python relaxuv sculpt sculptbrushes shader sketch sky sla spacemouse substance teamrender texturemanager thinking particles tpoperators volumes walkthrough X-Particles xpressocore xtensions ]
[2020-01-02 12:08:39][0] NVAPI initializing...
[2020-01-02 12:08:39][0] NVAPI Version: NVidia Complete Version 1.10
[2020-01-02 12:08:39][0] Nvidia driver version:441.66  [r441_58]
[2020-01-02 12:08:39][1] LoadOslScripts()
[2020-01-02 12:08:39][0] Loaded 171 osl scripts from dir:C:\Program Files\MAXON\CINEMA 4D R20\plugins\c4doctane\res\osl_scripts
[2020-01-02 12:08:39][1] LoadCustomLuts()
Remarks:
Apparently I'm a special case, because no one else has reported problems so far, and I also know that mostly incorrect user operation is the cause.
Yesterday I installed the latest NVidia drivers.
yesterday I tried the following as a test started with XB2:
- c4dOctane-R19.xdl64> c4d started without octane
- c4dOctane-R20.xdl64> c4d start hangs
- c4dOctane-R21.xdl64> c4d started without octane
>>> should be the expected behavior
HTK421
Thanks Ahmet.
We appreciate the constant development
BTW FYI,... the 'Title' in the live viewer still says XB1
Also,I couldnt find SETTINGS > OTHERS > c4d shaders
Do you mean SETTINGS > C4D SHADERS TAB ?
HTK421 wrote:Thanks Ahmet.
Also, the instructions are not quite right, SETTINGS > OTHERS > c4d shaders does not exist,
it is in SETTINGS > C4D SHADERS TAB.
Thanks for informing me, I'll rebuild and upload a fixed build with correct titling.
VVG
ok
I will try again
viewtopic.php?p=375169#p375169
Vectron Volumes - ? Is this *hit OSL primitives.txt or something new?
Spectron area/sphere primitives - ?
What is your habit of ignoring questions?
Something needs to be answered by users.
Tomorrow / later / never / I do what I want, etc.
thanks
Win 10x64, AMD 1950x 16C/32T, RAM 32Gb, RTX 3060x3
Octane-for-C4D(R23.110)2021.x.x, Cycles4D, Centileo. Nvidia 472.47 STUDIO
VVG wrote:ok
I will try again
thanks
Being more respectful that will be welcome! I'm giving answers when it's possible. I'm not on this sections and don't want to give wrong answers. Your question will be answered when I have answer
VVG
aoktar wrote:
VVG wrote:ok
I will try again
thanks
Who else should i ask Jules Urbach?
In standalone they are also silent, and I was not the only one asking how to work with it
viewtopic.php?p=375244#p375244
If you don’t have an answer, say so. I have no answer to this question yet
