Cinema 4D version 2020.1-XB2-R2 (EXPERIMENTAL) 10.01.2020
Hi all,
This is first and QUICK build of the plugin with EXPERIMENTAL 2020.1-XB2 SDK. I'm making this release to offer first RTX BUILD asap for letting test it. Also C4D noises are disabled until 2020.2 SDK.
Do not forget there are some uncompleted features and DO NOT USE for jobs. And OSX builds are not yet available. Any feedbacks are welcome for development and fixing the issues. Enjoy it!
This is the matching Standalone: OctaneRender™ 2020.1 XB2.
To use this version, you need a GPU of compute model 3.0 or higher. Support for Fermi GPUs (like GTX 4xx and 5xx) has been dropped. Also, make sure you use a driver of version 419.xx or higher and if you are working on Mac OS that has a CUDA driver installed that supports at least CUDA 9.1.
1- Use NVIDIA STUDIO drivers, not Game Ready versions. If you have stability issues try different drivers, some of them could cause instability issues. Do a clean install while doing this to be sure previous files completely removed.
Changes of 2020.1-XB2-R2
- Custom osl displacement button in VolumeMedium
- Picking volume objects from LV
- Added ACES rendering options
- Osl filename parameter, save as assets support
- Vectron support in Node Editor
_Volume-object-scenes: https://drive.google.com/open?id=1KWMS5 ... HKFiUKmlqC
- Multi storage for image comparison
- Improved hair material and interface
- C4D noises and gradient support. It's experimental and not matches pixel perfect the original. (Activate it from Settings/c4d shaders->use osl for c4d noise/gradient)
- Several plugin fixes
- Core improvements and fixes
Changes of 2020.1-XB1-Test2
- Performance improvement: Multi-threading support for material creation on sending a render. Activate it by Settings->Other->Multi-thread for materials
- Missing first clone of multi-instances
- Avoid lags due to unnecessary updates for VDB object under cloners
- Performance fix for vdb object for viewport
- Detection the animation for C4D noises
- Fix: Custom lut strength
WINDOWS ENTERPRISE BUILD (R15-R21)
https://render.otoy.com/customerdownloa ... R2_win.rar
WINDOWS SUBSCRIPTION(Studio) BUILD (R15-R21)
OSX ENTERPRISE BUILD (R15-R21)
https://render.otoy.com/customerdownloa ... Macosx.zip
OSX SUBSCRIPTION(Studio) BUILD (R15-R21)
Requirements:
-You'll need to update your Cinema 4D to latest versions(R16.050, R17.053, R18.057, R19.053, R20.057, R21.115). Otherwise, the plugin will not work and not appear in menus.
-Nvidia drivers at least Nvidia Studio Drivers(minimum 435.80) and be careful with latest Game Ready drivers which can cause cuda errors. Stay with stable one for you.
-Cuda 9.1 driver for OSX.
ONLINE HELP MANUAL
To use OFFLINE version of manual from plugin
Download following package and extract to Cinema4D/plugins/c4doctane/manual
https://render.otoy.com/plugindownloads ... p-html.zip
V3 SAMPLE SCENES SET(make a request if you need any specific sample)
https://render.otoy.com/plugindownloads ... scenes.rar
See this topic for some partial samples: viewtopic.php?f=85&t=53989
CINEMA 4D TUTORIALS SECTION: viewforum.php?f=87
CHANGE LOG: https://docs.otoy.com/#60Change%20log
Installation
Ex. if you have Cinema4D R18.0, keep only "c4dOctane-r18.cdl64" and delete c4dOctane-r17.cdl64, c4dOctane-r16.cdl64, c4dOctane-r15.cdl64, etc..
Cinema 4D Release 15: c4dOctane-r15.cdl64 or c4doctane_R15_demo.dylib
Cinema 4D Release 16: c4dOctane-r16.cdl64 or c4doctane_R16_demo.dylib
Cinema 4D Release 17: c4dOctane-r17.cdl64 or c4doctane_R17_demo.dylib
Cinema 4D Release 18: c4dOctane-r18.cdl64 or c4doctane_R18_demo.dylib
Cinema 4D Release 19: c4dOctane-r19.cdl64 or c4doctane_R19_demo.dylib
Cinema 4D Release 20: c4dOctane-r20.xdl64 or c4doctane_R20_demo.xlib
Cinema 4D Release 21: c4dOctane-r21.xdl64 or c4doctane_R21_demo.xlib
thanulee
Happy new year Ahmet! Thanks a lot for this update!
thanulee wrote:Happy new year Ahmet! Thanks a lot for this update!
Thanks mate, enjoy it!
m2001
Happy new year and Thanks for the new Version.
C4D does not start with 2020.1-XB2
Hangs at "Initialize plugins" (I waited about a minute)
C4D Version: R20.059
Files/Folders in my in /plugin/c4doctane/ Directory seems ok:
/Libs300
/res
c4dOctane-R20.xdl64
Rollback to 2020.1-XB1-Test2 (EXPERIMENTAL)
- C4D start > ok
m2001 wrote:Happy new year and Thanks for the new Version.
/Libs300
/res
c4dOctane-R20.xdl64
should be in to "/plugins/c4doctane/" not "/plugin/c4doctane/"
- C4D start > ok
m2001
/Libs300
/res
c4dOctane-R20.xdl64
sorry typo ... it is and it was in /plugins/c4doctane/
path
path
Update:
- PC reboot
- new download 2020.1-XB2
- c4d start > hangs
-> windows taskmanager > c4d with 7-8% CPU (waited 2 minutes)
- back to 2020.1-XB1-Test2 > works
pxlntwrk
Happy New Year, and thanks for new release!
it's really cool to finally be able to use non-baked native c4d noise :D
pxlntwrk.net
m2001 wrote:
Update:
- PC reboot
- c4d start > hangs
Check you installation for double install
ryanaexavier
Awesome work!! Vectron materials are working again!!
I was wondering if I should be expecting speed gains with RTX turned on when rendering vectron objects as they are not actual geo? I wasn't seeing any speed gains at all with RTX off vs RTX on when rendering one.
I then moved on to test a 8.9 million tri object and noticed the render time went from 20 minutes to around 16, just wondering if that sounds about expected?
Lastly, below are my results of that 8.9 million tri object, in a render comparison, using the PT kernel with RTX OFF on the left and RTX ON on the right. Maybe a bug or something?
Thanks again AOKTAR!!!!!
ryanaexavier wrote:Awesome work!! Vectron materials are working again!!
I cannot answer core related questions, better to ask in standalone topic. Even render differences are not about plugin part. But I can ping the team if you send a sample scene.
