OctaneRender™ 2019.1.3
vijay
funk wrote:
aoktar wrote: As far as my tests it works well
It seems to only work correctly for "Mesh UV" projection (which you are using). My example is using an "XYZ to UVW" projection.
I just tried changing yours to "box" projection and see similar problems. It almost looks like incorrect vertex normals are being created?
Auto bump currently works only if the mesh is UV mapped. I'm fixing it now. Sorry.
funk
vijay_thirukonda wrote:Auto bump currently works only if the mesh is UV mapped. I'm fixing it now. Sorry.
Thanks Vijay :)
funk
Crash using vertex displacement mixer
1. Load the orbx
2. Right click the diffuse material > render
Octane crashes to the desktop
linograndiotoy
Using a normal or a bump map with the Toon Material doesn't work properly anymore (no bump or normal effect shows up). I think it never worked in 2019.x.
It works fine in 2018.
Toon_Normal_Bump_issue.orbx
Thanks!
wallace
linograndiotoy wrote:Using a normal or a bump map with the Toon Material doesn't work properly anymore (no bump or normal effect shows up). I think it never worked in 2019.x.
Thanks!
Thanks for the report, this will be fixed in the next revision.
funk
I'm seeing some artifacts in this specular material, which don't happen in 2018.1.3
linograndiotoy
funk wrote:I'm seeing some artifacts in this specular material, which don't happen in 2018.1.3
Hi! It looks like a value of 1.0001 is triggering the issue. It's ok as the value is >= 1.00049.
funk
Yes its only happening on smaller values. The modo plugin seems to be generating these values for its "on the fly" conversions in some cases.
Anyway, since its working correctly in 2018, it should be fixed in 2019.
BCres
Is there a CPU "old generation: limitation on this release? Here is my situation.
My main system with a 2080ti and new core i7 works great. Also, working with it is my slave machine with a 1080ti and 980ti. Everything works fine. The older system cpu is a Q9450 Core 2 quad. But it works great as a slave system.
But if I take an orbx file to the slave (and I am taking a small one). Start my second license of Octane standalone on it. The program starts up fine, loads the file, but as soon as I try to render the scene, the program just disappears to the desktop. No errors or anything.
So why can't the second machine handle the simplest little orbx files? Everything about the prefernces shows it's ready and using both GPUS.
Again, this slave works fine as a support to the main when I'm working. I just can't use the standalone version on it.
wallace
No worries, I'll fix this for the next release.
