OctaneRender® for 3ds max® v2018.1.2 - 7.06
HHbomb
Hi, Paride this is something we talk about already...
viewtopic.php?f=27&t=70933&p=358893#p358893
Any news ?
paride4331
HHbomb wrote:Hi, Paride this is something we talk about already...
Any news ?
Hi HHbomb,
Currently, the only way is to delete the folder manually:
C:\Users\YOUR_USER_NAME\AppData\Local\OctaneRender\cache
delete the folder 'texCache'
clear cache button in next release.
Regards
Paride
HHbomb
Thanks.
In 7.06 with the octane render viewport opened when hidding an object it disappear. Normal.
Then unhide it, the object don't reappear in the render window. It is a different behaviour than in all version before. You must rebuild de scene.
paride4331
HHbomb wrote:Thanks.
Hi HHbomb,
yes you're right 7.05 works as well.
Regards
Paride
coilbook
Hi Paride,
Do you know if octane now supports multiple color liquids/smoke in one Phoenix grid? If not can you please send this to Otoy. It is a very important feature. I asked for it many times but no answer. Thank you.
paride4331
coilbook wrote:Hi Paride,
Hi coilbook,
added to list.
Regards
paride
coilbook
Hi coilbook,
added to list.
Regards
paride
Thank you!
acc24ex
OK so material update on phoenixfd volume works on max 2020, but not 2017
.. tried setting the octane global preferences same as on 2020, but still no luck (is there a reset octane global to default?)
edit
..now sort of works, but sometimes doesnt.. OK how do we reset octane global preferences cause it might be one of those
BTW is there an option to start all object as movable proxy as default start option - really every other ipr renderer does it like that, and I always end up enabling everything
HHbomb
Nearly one month I find Monday cheerless….
richardyarlett
NEW BUG introduced. This is also a bug with V4 latest version.
When you hide an object that is a proxy, it disappears from the live viewer as normal.
When you UNHIDE that object it does not reappear. You have to then manually REFRESH the scene.
BIG PROBLEM.
