Hi, Paride this is something we talk about already...
viewtopic.php?f=27&t=70933&p=358893#p358893
Any news ?
OctaneRender® for 3ds max® v2018.1.2 - 7.06
- paride4331
Hi HHbomb,HHbomb wrote:Hi, Paride this is something we talk about already...
Any news ?
Currently, the only way is to delete the folder manually:
C:\Users\YOUR_USER_NAME\AppData\Local\OctaneRender\cache
delete the folder 'texCache'
clear cache button in next release.
Thanks.
In 7.06 with the octane render viewport opened when hidding an object it disappear. Normal.
Then unhide it, the object don't reappear in the render window. It is a different behaviour than in all version before. You must rebuild de scene.
- paride4331
Hi HHbomb,HHbomb wrote:Thanks.
yes you're right 7.05 works as well.
- paride4331
Hi coilbook,coilbook wrote:Hi Paride,
Do you know if octane now supports multiple color liquids/smoke in one Phoenix grid? If not can you please send this to Otoy. It is a very important feature. I asked for it many times but no answer. Thank you.
added to list.
paride
paride4331 wrote:Hi coilbook,coilbook wrote:Hi Paride,
added to list.
paride
Thank you!
OK so material update on phoenixfd volume works on max 2020, but not 2017
.. tried setting the octane global preferences same as on 2020, but still no luck (is there a reset octane global to default?)
edit
..now sort of works, but sometimes doesnt.. OK how do we reset octane global preferences cause it might be one of those
BTW is there an option to start all object as movable proxy as default start option - really every other ipr renderer does it like that, and I always end up enabling everything
edit
3dmax, zbrush, UE
//Behance profile //BOONAR
Nearly one month I find Monday cheerless….
- richardyarlett
NEW BUG introduced. This is also a bug with V4 latest version.
When you hide an object that is a proxy, it disappears from the live viewer as normal.
When you UNHIDE that object it does not reappear. You have to then manually REFRESH the scene.
BIG PROBLEM.
BIG PROBLEM.
