Version 4 - XB2.1 (Test release)
- leonthegod
When will the 2 gpu limit be removed from the subscription plugin?
Hi moebius,moebius wrote:strange thing happens during animation. PArt of the Model gets torn apart
here the scenefile
https://www.dropbox.com/s/x6zbshqv8jp9m ... t.c4d?dl=0
very strange behavior!
but I fixt it by puting a Octane Tag on the animated null with Force Updates Enabled, I renderd 25 Test Frames and it looked fine.
cheers
Once V4 replaced V3 as the latest stable release.leonthegod wrote:When will the 2 gpu limit be removed from the subscription plugin?
- aparksproject
here the scenefile
i tested the denoiser in animation and my geometry was also torn apart. The solution was to give the animated objects the octane tag with "force updates" set to enabled in the main tab. Maybe try that
