Version 4 - XB2.1 (Test release)
Hi All,
This is very quick test/preview release of plugin which is based on V4-XB2.1 SDK. We recommend that you mention that it is experimental, they should not use it for production work, and that we cannot guarantee backward compatibility.
Please see this thread for V4 features: viewtopic.php?f=33&t=66013
Standalone: viewtopic.php?f=33&t=67492
Important notes:
Since XB2 Preview, we have dropped support for Fermi cards.
Network render is still disabled.
Denoiser does not denoise volumes or hairs yet.
Denoiser is under Camera Imager from Settings or Camera Tags. Just denoised beauty pass is available in plugin, others will be added.
Addons for plugin side
- Viewport rendering: Activate from Live Viewer/Octane dialog options menu. Keep open the one of these windows during the render session.
- Node Editor: Experimental float sliders on nodes. Need to activate from "settings->nodes->embedded gui".
- Node Editor: Show/hide options for node pins.
- New help system, updated manual(it's still wip). Access by help icons from nodes/etc..
- Several minor fixes.
WINDOWS REGULAR BUILD
https://render.otoy.com/customerdownloa ... .1-win.rar
WINDOWS SUBSCRIPTION(Studio) BUILD
OSX REGULAR BUILD
https://render.otoy.com/customerdownloa ... .1-OSX.zip
OSX SUBSCRIPTION(Studio) BUILD
https://render.otoy.com/customerdownloa ... B2-osx.zip
Requirements:
-You'll need to update your Cinema 4D to latest versions(R16.050, R17.053, R18.057, R19.053). Otherwise the plugin will not work and not appear in menus.
-Internet connection for activation, be sure that C4D and Octane will not be blocked by firewall and any antivirus software.
-Updated Nvidia drivers(most recents like 39x.x) with Cuda 9.1 - change driver versions if you have much trouble with current driver
V3 SAMPLE SCENES SET(make a request if you need any spesific sample)
https://render.otoy.com/plugindownloads ... scenes.rar
See this topic for some partial samples: viewtopic.php?f=85&t=53989
CINEMA 4D TUTORIALS SECTION: viewforum.php?f=87
CHANGE LOG: https://docs.otoy.com/#60Change%20log
Installation
First remove all octane related stuff from plugins and main folder of Cinema4D.
Also download manual.zip and extract to c4dOctane directory if it's not available in place.
Ex. if you have Cinema4D R18.0, keep only "c4dOctane-r18.cdl64" and delete c4dOctane-r17.cdl64, c4dOctane-r16.cdl64, c4dOctane-r15.cdl64, etc..
Cinema 4D Release 13: c4dOctane-r13.cdl64
Cinema 4D Release 14: c4dOctane-r14.cdl64
Cinema 4D Release 15: c4dOctane-r15.cdl64 or c4doctane_R15_demo.dylib
Cinema 4D Release 16: c4dOctane-r16.cdl64 or c4doctane_R16_demo.dylib
Cinema 4D Release 17: c4dOctane-r17.cdl64 or c4doctane_R17_demo.dylib
Cinema 4D Release 18: c4dOctane-r18.cdl64 or c4doctane_R18_demo.dylib
Cinema 4D Release 19: c4dOctane-r19.cdl64 or c4doctane_R19_demo.dylib
Node sliders
https://vimeo.com/268974364
Viewport rendering mode
https://vimeo.com/265747658
https://vimeo.com/265294205
Overdrive_Studios
omg thanks!! Is the Windows subscription link correct? I guess it's downloading the OSX version :P
Overdrive_Studios wrote:omg thanks!! Is the Windows subscription link correct? I guess it's downloading the OSX version :P
Yes, fixed now! Thanks!
raulofs
Hi, aoktar
"When will light passes be supported in the denoiser?"
Thank You
thodosplay998
Hello aoktar, i've found inverted icons on the glossy and specular material.
The specular icon glossy, and the glossy icon specular.
artdude12
Those are the updated icons. I think they should be switched as well.
i7 4930K_Asus_RampageIV-Extreme_64GB_3-Titan_NVIDIA-337.88_Win7-64
Overdrive_Studios
Is it normal that if I activate AI Lights, my render is horribly noisy? Maybe i'm missing something else :(
AI Lights ON: https://i.imgur.com/STTNjpG.jpg
AI Lights OFF: https://i.imgur.com/uNyh9Ee.jpg
Also, x-particles seems to be broken for some reason. If I use an emissive material with trails and xsplinemesher, the material flickers a LOT through the render. I'll submit a couple files later :P
Thanks in advance!!
Last edited by Overdrive_Studios on Fri May 25, 2018 1:29 pm, edited 1 time in total.
moebius
strange thing happens during animation. PArt of the Model gets torn apart
here the scenefile
https://www.dropbox.com/s/x6zbshqv8jp9m ... t.c4d?dl=0
zinogino
Thanks for the release but I'm constantly getting CUDA related render failure on a simple scene.
I'm on Nvidia 397.93 version.
artdude12
moebius
I tried your file and got the same result. I also tried to connect & delete the legos and that seemed to work, but that obviously negates any animation of the parts.
Also, I tried rendering with the standard render and no problems. I also tried rendering with Redshift and no problems. So it seems to be an Octane issue.
I hope someone can resolve this for you.
