OctaneRender™ Standalone 3.08.1
wallace
funk wrote:I've been testing out some SSS materials using a specular material. GGX and beckman BRDFs create some really bright pixels in the medium that are very difficult to clean up. The "octane" BRDF doesnt do this.
Is it possible to fix this? I've attached a test file, although it seems to be worse in my actual scene.
If you load the orbx and change the "model" material to "octane" brdf, you see those bright dots dont appear.
I have noticed this issue a couple of days ago and I have already went and fixed this issue. Having just doubled checked with your scene and your material, I can confirm this is now fixed.
The fix will be in the coming 3.08.2.
Wallace
funk
Awesome. Thanks wallace :)
aufwind
Dear Nvidia, Dear Otoy,
after updating to Nvidia Drivers 397.93 my Titan X (Pascal) wouldn't render anymore (GPU failed).
The Titan Kepler Cards were still working. This happened both with Octane 3.07 and 3.08.
Reverting back to Drivers which I mistakingly thought was 390.77 (rather was 391.xx)
firstly was working without rebooting the system. After shutting down the Computer,
I was unable to start the Computer again (PSU failure). After changing PSU, WIN 7
wouldn't start anymore. I was unable to recover the System and had to reinstall Windows.
After updating Nvidia Drivers to 390.77 again, Windows wouldn't boot anymore.
I went back to Drivers 388.71. Now the System is working fine again.
I also reported this directly to NVIDIA.
The PSU failure might be coincidentally, but this is ...
Win7 | Gigabyte G1.Sniper 3 | I7 3770K | 2x Titan (Kepler) | 1x Titan X (Pascal)
nuno1980
aufwind wrote:Dear Nvidia, Dear Otoy,
Use DDU (Display Driver Uninstaller):
1. Uninstall GeForce driver with reboot REQUIRED
2. Use DDU on SAFE MODE
3. Reinstall GF driver or Install new GF driver. ;)
PT vs PHT kernels - spp nrs
Caustics at PT
i7-12700KF
32GB DDR4@3600
GF RTX 4090 <3 :mrgreen:
NEW ViewSonic XG2431 24" :D
funk
Im just testing out something with instances and noticed Instance range "invert", doesnt seem to do anything when checked.
PolderAnimation
I posted this in the wrong thread an was asked to redirect to this topic, so this is a partial repost. Sorry for that.
We are experiencing license authentication errors when 2 octane instances start more or less at the same time.
We use a proprietary render dispatcher that is build in python to run standalone, but in the end it just starts octane on the specified slave PC's with the following command parameters "--stop-after-script" and "--script" pointing to an on the fly generated lua script ( table with shot and renderJob info and a call to our lua pipeline batchRender script ) to start the rendering process inside octane.
We only run 2 slave units on a render PC when the loading times are substantially higher than the per frame render times. And even then the chance that 2 octane jobs start simultaneously is small, but is has happened more than once that one instance stopped due to this error massage and since our batch job doesn't finish until octane exists, we had 1 of the 2 slaves idle for a whole weekend, which is not desirable when chased by deadlines ;)
This problem is not specific to our render dispatcher, as the problem arises as well when you start two octane instances at the same time ( by clicking the app icon quickly after each other ;) )
This even happens when octane has run just before and thus the PC has been authenticated only minutes before.
I attached a screengrab of our renderDispatcher ( just for fun ) and one of the error message.
Is this something that is circumvent-able, by means of automated retry timer or is it on the bug-fix-list?
Cheers
Jean-Paul Tossings
Win 11 | Dual RTX 5090 | AMD Ryzen 9 9950X| 192GB
manalokos
Didn't any of you have problems with the Undo command, reverting to some several undos before?
mojave
PolderAnimation wrote:I posted this in the wrong thread an was asked to redirect to this topic, so this is a partial repost. Sorry for that.
Cheers
Jean-Paul Tossings
Hi Jean-Paul,
What you see is not an error but a dialog we display when you start Octane and another instance is currently authenticating, which can happen just once at a time.
One possible solution would be to have your Lua script communicate to your Python script, maybe via a file or internal sockets that it's started running or else kill the process and try again after a timeout that sounds reasonable.
Please PM me if you need more help.
zoppo
Is the Offline Mode back again? I can't use 3.08 w/o my render clients.
Mon Apr 23, 2018 9:53 pm:
Goldorak wrote:Sorry for the inconvenience - while this is otherwise a feature complete release, we should have also noted that the offline system for 3.08+ is still at least a week or more out as we compete testing on a new backend for this. If anyone requires offline mode sooner, I’m recommending staying on 3.07 for just a little longer. Please contact help desk if there is a hard and immediate requirement for offline mode with 3.08.
C4D 2025 | Win10
fabian19
the daemon won´t launch on my MacPro5.1
Started logging on 07.06.18 10:00:01
OctaneRender 3.08.1 (3080100)
Launching net render slave (3080100) with master 0.0.0.0:0
detected that slave is hanging after initialization -> stopping slave
failed to send stop message to slave
Stopped logging on 07.06.18 10:00:19
logout
Saving session...
...copying shared history...
...saving history...truncating history files...
...completed.
[Prozess beendet]
I updated all the Nvidia drivers and CUDA
3.08 runs fine.
any hint for me ?
Regards,
Fabian
