VisibleBackground c4d Xpresso
Sub forum for help and tutorials.
cendrick
This is fantastic,
Quick question...the background image looks amazing. How can I now make it an image sequence so I can put in a video for example?
Rick
Jamma
Hey guys is it possible to make the background a movie?
TonyBoy
Make it a material on a panel that you can create an image sequence as long as you like using C4D animation.
Jamma
cool thanks for the help :)
GIOLETS
Hi Beppe! How are you?
I use this useful script quite every day and is really a must!
I ask if is possible to solve in some way (perhaps my fault) the situation when you can't have a Camera not tilted because in this case the background image don't fit the screen.
There is a simple workaround?
Thanks again for your help.
Luca
i9-10900x, 96GB DDR4, 2xRTX 2080 TI, ASUS X299 SAGE, Windows 10
http://www.visual4d.it
Ciao Luca,
everything seems to work as expected here with X, Y, Z camera rotation :roll:
ciao Beppe
GIOLETS
Hi dear Beppe!! How are you??
Please check if you see the problem rotating the camera angle "P" to +5° (positive).
Thanks again.
Luca
AndrewStrasser
Dear Octane Developers!
You guys are awesome!!! Thank you for all the hard work!
I was wondering if it would be possible to add this functionality direclty into the plugin so that it is not some kind of an xpresso work around?
Thank you! Redshift has a very clear way of adding a background, so Octane should as well!!!
Big Bless,Andrew
muchogrande
Thank you for this Beppe! It's great, but I am having the same issue as Luca. The plane is not following P rotation (H and B work as expected).
Sorry, so many things, and it is a long time that I don’t check this, but I think we have solved with Luca by using the following cameraMap_environment.osl script by Calus:
viewtopic.php?f=21&t=65575
Please Luca, help me remember this :D
ciao Beppe
Return to “Help / Tutorials”
