Saving and reusing presets materials
swang
Hi Paul,
When I save out a octane material using the command "octane.exportmaterial," I can successfully save out as both formats. However, when I try to import the files into a different scene, I'm getting the message "error loading octane/modo material."
Do you by any chance know the problem?
Thanks!
Hi - can you pls provide the information requested at the top of viewtopic.php?f=34&t=55078.
swang
- Modo version: 902 SP3
- OctaneRender for Modo version: 3.6.5.118
- Operating System: Win 10
- Amount of RAM: 64GB
- Graphics Card(s) - model: 980ti
- Nvidia driver version: 382.05
Thanks. How are you importing the saved OCS/ORBX back into the scene pls?
swang
I am just typing in the command octane.importlivedb. The error shows up with both files type.
Thanks. I can replicate this problem, and it will be fixed in the next release.
swang
Greatly appreciated! That button would also be nice :) I'll be happy to provide any "art" you may need for that.
If you post the graphic here, I will add it.
swang
Hi Paul,
What types of file is the best for these icons? PNG or JPEG?
Also, thank you for fixing the bug with import. I just tried it, and there seems to be another problem. It only imported the "base" material, no texturemap or node settings. For example, a material using the liveDB Aluminum as a base would simply import in as the base Aluminum.
PNG pls.
I think I have resolved this in the next release, which I will post a pre-release of in the next few days.
Return to “Foundry Modo”
