failed to write texture....... two year old bug
azen
Jorgensen wrote:hi captaincrowbar
sadly the same error.
but i just tried to copy the octane plugin
from
C:\Users\brj\AppData\Roaming\SketchUp\SketchUp 2016\SketchUp\Plugins
to
C:\Users\brj\AppData\Roaming\SketchUp\SketchUp 2015\SketchUp\Plugins
and now i don't get the error when using skectup 2015??
jorgensen
So this bug occurs in 2016, but not in 2015? That changes the direction of the troubleshooting a bit. Thanks for the insight, very much appreciated.
CaptainCrowbar
Hi Jorgensen,
I've just made another release with some more changes to the file path code. Please give this a try.
Sorry this is turning out to be so hard to fix; it's always a pain to debug an issue that only shows up on the customer's system and won't show its face around here :) It's something to do with the interaction between the particular way your networked user partitions are set up and the code that determines where to save files; I'm trying to narrow down exactly what's going on here.
Jorgensen
hi captaincrowbar
i can imagine how difficult it must be to solve userside errors - i therefore really appreciate your effort!!
i have just tried out your lastest release.....
the good thing first
the error has gone :-)
the bad thing
the geometri has gone also :-/
when i create a simpe box with a simple su color material, everything is fine - but if i add a su material that contain an image the geometry dissapears - both before and after i press the reload arrow :-(
jorgensen
CaptainCrowbar
Thanks! I think the new problem may be related to another issue I'm looking into. Will get back to you on that.
Return to “SketchUp”
