OctaneRender® for Maya® 3.03.1 - 8.0 Win [ALPHA]
- matrix2012
No Alpha Version of Linux.
I am very sad.
Wait Wait Wait ....
Octane for Maya Linux Alpha version.
When can I expect.
Sorry for my bad English
I am very sad.
Wait Wait Wait ....
When can I expect.
- Jolbertoquini
- Contact:
Thanks Kai awesome...
Octane Render for Maya.
https://vimeo.com/jocg/videos
http://www.hmxmedia.com/
Thanks!
... but unfortunately I have to join the choir of people reporting crashes. Maya crashes instantly when telling it to load OctanePlugin.mll. Tried with Script Editor open and Echo All Commands on, but there was no new output. Tested at home machine using Win10 & Maya 2016 (no service packs, Maya student license). Standalone 3.01.1b is installed and activated and works beautifully. Uninstalled Maya plugin v2 too, did not help.
Installing Maya SP6 at the moment to see if it makes a difference. *EDIT: nope, still crashes with SP6 exactly like before* If you need more details, ask.
- Stollentroll1984
Same here,
Maya crashes always I click the load button in the Plugin-Manager.
Maya 2016 SP6 , Win 10 x64
Did it work for anyone? Jolbertoquini?
You were the only one that didn't report crash. Did you try it? If so, anything out of the ordinary about the installation?Jolbertoquini wrote:Thanks Kai awesome...
GTX 1080 8gb, GTX 970 4gb, I5 4590, Z97-E, 32gb RAM, Win 10 64bits, Octane for Maya
- cgsingularity
I'm having the same issue mentioned above. When I check octane render in the plug in manager Maya crashes immediately.
- Jolbertoquini
- Contact:
Hi Ivan,ivankio wrote:Did it work for anyone? Jolbertoquini?You were the only one that didn't report crash. Did you try it? If so, anything out of the ordinary about the installation?Jolbertoquini wrote:Thanks Kai awesome...
Was just for happiness but unfortunately doesn't work for me at office I tried 2014/2015/2016 with different standalone still Crash. at load moment
I will check at my home I think was working 2015. let you guys know.
cheers
- cyrillweiss
Also reporting Crash with Maya..
- 2015 SP6
- 2016 ext1 SP6
The Installer didn't copy the plugin to Maya 2016 ext2 SP1, so I had to copy it manually to C:/Program Files/Autodesk/Maya2016.5/bin/plug-ins/OctanePlugin.mll. When loading it, I get following error message:
"Das angegebene Modul wurde nicht gefunden" is German and translates to: "The given module has not been found"
Maybe it was not enough, just to copy the OctanePlugin.mll to the plug-ins folder, so I'm not sure, if it is of any help.
cheers
- 2015 SP6
- 2016 ext1 SP6
// Error: line 1: Unable to dynamically load : C:/Program Files/Autodesk/Maya2016.5/bin/plug-ins/OctanePlugin.mll
Das angegebene Modul wurde nicht gefunden.
// Error: line 1: Das angegebene Modul wurde nicht gefunden.
(OctanePlugin) //
cheers
HW01:WIN10x64/X79/i7-3930K/64gb/GPU:1xTitan X, GTX 1080ti, SW:Maya2018/2019, Cinema 4D R20
HW02:WIN10x64/Z370/i7-8700K/64gb/GPU:1xTitan X, GTX 1080ti SW:Maya2018/2019, Cinema 4D R20
etc. ...
etc. ...
