Maya® Version Requirements
This release will work with Maya® Versions 2014, 2015 and 2016 64-bit on MS Windows operating systems.
You cannot purchase and use only the Maya plugin and use it without also owning an activated copy of OctaneRender™ Standalone on your machine.
HOW TO PURCHASE LICENSES
You can purchase both the OctaneRender™ Standalone Edition and the OctaneRender™ for Maya® Edition as a reduced price bundle, purchase the bundle priced at 619€
Purchase an "OctaneRender™ for Maya® License" priced at 269€
LICENSE MANAGMENT
Just like OctaneRender™ Standalone, the Maya® plugin license activation is done at startup in the activation pop up window.
Deactivating the plugin license can be done from within Maya® (render settings window / octane license tab).
ALPHA DISCLAIMER
Please note there are known issues due to ongoing development, which are detailed in an extra post, next to this one.
V3 DOCUMENTATION
Documentation
 1. New node based system analog to the standalone node system
 2. Node editor based workflow
 3. Volume nodes connecting to Maya® Fluids
 4. Additional volume nodes for configuring volume rendering
 5. CameraTransformConverter node connecting to Maya® Camera
 6. Lost&Found node for keeping additional nodes (kernels, cameras) connected to the main node graph
 7. SDK 3.03.1 integration
DOWNLOAD
OctaneRender for Maya 3.03.1 - 8.0
OctaneRender for Maya 3.03.1 - 8.0 Demo
viewtopic.php?f=24&t=54805
Yours,
The OctaneRender™ Team.
