Rendering Artifact with Max Tile Samples
I couldn't reproduce any issues with the original scene, but regarding the other cases: Are you using network rendering? If yes, please disable the option "minimize net traffic", but also be aware of the consequences (see "Overhauled work distribution network rendering" in viewtopic.php?f=33&t=51679 ).
I was not using network rendering in my case.
Then can you send me the scene please? Also which version did you use and which operating system?wafflelad wrote:I was not using network rendering in my case.
Sure, it was linked in the first post...
https://dl.dropboxusercontent.com/u/108 ... werFog.zip
System:
2009 8-core Mac Pro / 32gb ram / OS X 10.11.5
Octane 3 R1.1
780 ti in slot one (x16) with external power
GT120 in slot two for displays
System:
Octane 3 R1.1
Thanks a lot. As I said I couldn't reproduce the problem with that scene. Did you have the same problem with a later release of the C4D plugin? Does it occur all the time / is it reproducible?wafflelad wrote:Sure, it was linked in the first post...
System:
Octane 3 R1.1
OK, turning off the "minimize net traffic" option seems to solve this for me -> Thank you abstrax !
best
Andreas
best
Andreas
1 x 4090 GTX, 1 x 3090 GTX
http://www.v-cube.de
Ok, I updated to R2. The original streamlined scene I uploaded renders fine. The full version of that scene, with hair and a lot more geometry, still renders with the artifact. That scene is here if someone wants to try it...
https://dl.dropboxusercontent.com/u/108 ... ogFull.zip
Ok, thanks for your scene. I can reproduce the issue here now.wafflelad wrote:Ok, I updated to R2. The original streamlined scene I uploaded renders fine. The full version of that scene, with hair and a lot more geometry, still renders with the artifact. That scene is here if someone wants to try it...
EDIT: When I remove the trees, the issue goes away...
