Rendering Artifact with Max Tile Samples
abstrax
I couldn't reproduce any issues with the original scene, but regarding the other cases: Are you using network rendering? If yes, please disable the option "minimize net traffic", but also be aware of the consequences (see "Overhauled work distribution network rendering" in viewtopic.php?f=33&t=51679 ).
wafflelad
I was not using network rendering in my case.
abstrax
wafflelad wrote:I was not using network rendering in my case.
Then can you send me the scene please? Also which version did you use and which operating system?
wafflelad
Sure, it was linked in the first post...
https://dl.dropboxusercontent.com/u/108 ... werFog.zip
System:
2009 8-core Mac Pro / 32gb ram / OS X 10.11.5
Octane 3 R1.1
780 ti in slot one (x16) with external power
GT120 in slot two for displays
abstrax
wafflelad wrote:Sure, it was linked in the first post...
System:
Octane 3 R1.1
Thanks a lot. As I said I couldn't reproduce the problem with that scene. Did you have the same problem with a later release of the C4D plugin? Does it occur all the time / is it reproducible?
slepy8
On ver 3 R2 - I don't get the issue.
just FYI
v-cube
OK, turning off the "minimize net traffic" option seems to solve this for me -> Thank you abstrax !
best
Andreas
1 x 4090 GTX, 1 x 3090 GTX
http://www.v-cube.de
wafflelad
Ok, I updated to R2. The original streamlined scene I uploaded renders fine. The full version of that scene, with hair and a lot more geometry, still renders with the artifact. That scene is here if someone wants to try it...
https://dl.dropboxusercontent.com/u/108 ... ogFull.zip
slepy8
Now I reproduced the problem too.
There is a well visible line.
abstrax
wafflelad wrote:Ok, I updated to R2. The original streamlined scene I uploaded renders fine. The full version of that scene, with hair and a lot more geometry, still renders with the artifact. That scene is here if someone wants to try it...
Ok, thanks for your scene. I can reproduce the issue here now.
EDIT: When I remove the trees, the issue goes away...
