Rhino crashes by showing object propeties - material
Micha3D
Here two screenshots. Octane is disabled to prevent crashes during using Vray. I try to manual load the plugin.
Win7 64 | Dual Xeon E5-2687W | GTX 1080ti 11GB + GTX 780 6GB | Rhino3D
Tick the "Enabled" checkbox.
Micha3D
No, this doesn't work for the current Rhino session and I don't want a permanent loading. I'm looking for a manual load if needed only. I have seen this is a Rhino bug and I post it at the Rhino forum now.
http://discourse.mcneel.com/t/manual-lo ... ng/23384/1
Micha
I use the latest version now and I get still this crashes if VfR is enabled and I jump to the material properties.
http://www.simulacrum.de - Visualization for Designer and Architects
Win7 64 | Dual Xeon E5-2687W | 32GB RAM | 2 GTX 780 6GB | Rhino3D
This is potentially a bug in VfR when it is trying to render the thumbnail for an Octane material. Can you send me a crash report pls?
Micha
Is on the way, Rhino is sending the report.
McNeel will analyse the report, and if it crashed in the Octane plugin, they will send it to me, however if it crashed in the VRay plugin, it will get sent to the Chaos Group devs.
Micha
Paul, please add an option to disable the message, that Octane needs to be enabled to get the right material preview. Please add a little flag option at the material info message like "never show this message again".
Once again, here the error message.
This looks like an exception occurring inside the Rhino RDK. Are you able to give me a set of steps so I can try to reproduce this error pls?
Micha
The Octane plugin is enabled at the plugin list, but not the current render. Important step: choose Rhino renderer, disable the Octane UI at the properties tab, close Rhino and restart (Also for this test I disabled the Vray plugin before, so it's not loaded during the crash. Rhino crash with and without Vray is loaded at the background, so the Octane crash shouldn't be caused by the Vray plugin).
Than I open a file where I used Vray for Rhino before (like attached file) and enable the Octane UI at the properties tab . Than I go to the object properties. Octane message for better preview is shown. Press ok. Crash.
SpecularTest.zip
(50.82 KiB) Downloaded 251 times
