Animated Water Texture
- 3dreamstudios
Interesting...have not run across this. Looks very promising. For others here are some links I found...mikefrisk wrote:You could also try the Houdini Ocean Toolkit. The displacement works with octane.
https://www.lightwave3d.com/assets/plug ... lightwave/
https://code.google.com/p/hotocean4lw/downloads/list
I tried this looong time ago and had forgotten about it, thanks for reminding3dreamstudios wrote:Interesting...have not run across this. Looks very promising. For others here are some links I found...mikefrisk wrote:You could also try the Houdini Ocean Toolkit. The displacement works with octane.
The Octane material displacement does not work but object deformation displacement does
Thanks!
AMD Ryzen Threadripper 2990wx (32c/64t),64GB RAM,NVIDIA GTX 1080ti,Win10
Clarisse 4,Houdini 18 (+Octane 2019),Blender2.81,Fusion360,Onyx,ZBrush,SubstPnt...
Started: Houdini 2019, Clarisse 2016
No business, just fun
- 3dreamstudios
I'm also going to try the Lightwave procedural texture I use normally, as I saw where Octane can use that as an image texture now! I think this is a new feature...you can use LW procedural s in Octane!
Yes it is relatively new (not brand new3dreamstudios wrote:I'm also going to try the Lightwave procedural texture I use normally, as I saw where Octane can use that as an image texture now! I think this is a new feature...you can use LW procedural s in Octane!
See here http://render.otoy.com/forum/viewtopic. ... le#p207332
Antti
