Asus P9X79 mobo Dual Titan X
treddie
Yeah - that's why it's not advised to save on PSU - these could kill entire system =)
My feelings exactly. Especially when you're putting down $1000.00 + for a GPU, and a PSU is only a fraction of that. Don't be penny-wise foolish.
Win7 | Geforce TitanX w/ 12Gb | Geforce GTX-560 w/ 2Gb | 6-Core 3.5GHz | 32Gb | Cinema4D w RipTide Importer and OctaneExporter Plugs.
Tutor
Location: Suburb of Birmingham, AL - Home of the Birmingham Civil Rights Institute
treddie wrote:Might want to be careful with going with just a 750W PSU...Even though you may never spike above that, it WILL run warmer than something more powerful, which means cutting into the lifetime of your 750W unit. I just like to be careful. IMHO it is also important if one of your fans happens to die on you, and you don't know it, which means your case will run even hotter. Heat kills and shortens the life of everything in your case.
I agree with your caveat about just going with a 750W PSU. His over clocking those GPUs will send that power curves disproportionate upwards, as each crank upwards uses more and more power. I typically see 120 to 130% above TDP with my over clocks. 375 x 2 = 750; 750 X 1.2 = 900.
Because I have 180+ GPU processers in 16 tweaked/multiOS systems - Character limit prevents detailed stats.
glimpse
as we could see from shown graphs - it's nothing bad to run 2x TitanX without OC even on 700W system, but..it's not advisable if You OC..-Tutor made a clear point with numbers =)
igor73
Will order a new PSU after reading this. Thanks for the advice. Main reason i did not order was laziness actually. Seems to be a lot of cables to fiddle with :) The cards i ordered are superclocked to.
DigitalOven
btw, I had just been shopping for PSU's and the EVGA Supernova (1000 to 1600w) gold ones on Amazon looked like a good deal and had good reviews ... I'm definitely not a systems builder so no idea how reliable these are but that's what I had been leaning towards
C4D R17 | OSX Mavericks | GTX 780 6GB | Mac Pro 4,1|GTX 780 6GB + GTX 680 4GB on Windows 7 box for slave|
igor73
Ok, will look at those to. Have been thinking of corsair 860W or 1000W. Can´t get more than 2 GPU´s in ny box anyway.
