i'm working on a competition but i will release some renders when it's 'legal'
once again - thanks nagboy.
jorgensen
Please could someone save the file as 3dsmax2014 for me....?nagboy wrote:Hi, you can have this simple scene from me. Good for stills. Just adjust the wave height in the displacement slot. Adjust water color in the reflectance slot. Adjust the size of the ocean by adjusting the size of the plane, the displacement map tiles. It looks even better if you use a HDRI map for lighting
Great results, glad it worked out for youJorgensen wrote:hi nagboy
thanks once again.
i have posted the images where i used your texture.
thanks for help.
see the images here:
http://render.otoy.com/forum/viewtopic.php?f=5&t=45538
Thanks for you upload. The Tif is huge and nicenagboy wrote:Hi, you can have this simple scene from me. Good for stills. Just adjust the wave height in the displacement slot. Adjust water color in the reflectance slot. Adjust the size of the ocean by adjusting the size of the plane, the displacement map tiles. It looks even better if you use a HDRI map for lighting
http://1drv.ms/1DhXs4a
The basic material of the water looks amazing. The repetition kills the fun though.nagboy wrote:Hi, you can have this simple scene from me. Good for stills. Just adjust the wave height in the displacement slot. Adjust water color in the reflectance slot. Adjust the size of the ocean by adjusting the size of the plane, the displacement map tiles. It looks even better if you use a HDRI map for lighting
