did anyone check under - Non organic - Metal - Scratched edges metal red, is that one working OK?
I'll try and upload more when I start playing with materials again, cause I have to switch to octane standalone, readjust if the material ball doesn't look right, and then upload..
some more procedural metals - got a good rust there
3dmax, zbrush, UE
//Behance profile //BOONAR
- perro_abombao
[quote="acc24ex"]I got me some nice rust via gradient etc..
- materials mostly procedurals, attacted is the material library but for 3dsmax 2015 - usually doesn't work in lower version..
-Hi thanks for sharing this!!!
...could you send in this way the maps for your material "metal black slight scratch dirt"??? please...
oh did I forget the maps - I think it was the scratch bump map from the metal in the liveDB .. the really scratchy one .. I'll check later
3dmax, zbrush, UE
- jeffbriant
- Contact:
scale the object way down - dirt shader is pretty much dependent on object size - it was "optimized" for the octane material preview object
- or change the radius parameter on the dirt node
3dmax, zbrush, UE
this is some very fine textures! - and good as a learning tool
thank for sharring.
thank for sharring.
as I mentioned above - this shader / dirt texture in general is dependent on object size - reduce it or change radius values in the dirt node
..actually just read now, maybe you should click on the other node, one furthest below usually has settings if I remember it
3dmax, zbrush, UE
