OctaneRender® for Maya® v1.17 beta [OBSOLETE]
ciboulot
Hi Jimstar,
Thanks for the investigation.
I will see on my pc if it is a problem from hardware first. Drivers, etc. Then I will see if it comes from Maya itself. Maybe too much versions of octane plugin installed.
Question regarding this matter: Do I have to get the latest version of the standalone to get the latest version of maya plugin to work correctly?
My textures are totally normal. TGA or TIFF, some times HDR for the octane sun and sky, but that's all.
I'm running on a GTX680 with latest drivers. I will check if there is an update.
Maybe I have to check that the deadline renders witch are in the background. Some vray renders are happening on the pc, and I think it calls the octane plugin at the begining as these scenes passed throught my PC.
I keep you posted
CIboulot
Laptop HP 8760w, I7, 16Go ram, Quadro fx3000m, Maya 2014, Octane 1.20a. Vimeo: http://vimeo.com/ciboulot/albums
ciboulot wrote:Question regarding this matter: Do I have to get the latest version of the standalone to get the latest version of maya plugin to work correctly?
Not nessesary...
RickToxik
Hi Jimstar,
thanks for the update! Would it be possible to remove the "Cannot connect to the Live DB, retrying in x seconds" pop-up? Being an offline user, I find it a little bit intrusive.. An option to disable the LiveDB update would be fun too, since it gives me error messages from the beginning of that feature even when I am not rendering with Octane.
With this version, it also prevented me to launch a batch rendering with mental ray. It was sticking on frame 1 while Octane kept trying to connect.
Regards
Next version HERE.;)
Return to “Autodesk Maya”
