OctaneRender® for Maya® v1.17 beta [OBSOLETE]
Maya® Version Requirements
This release will work with Maya® Versions 2011, 2012, 2013 and 2013.5 / 32-bit & 64-bit on MS Windows operating systems.
OctaneRender™ for Maya® implements almost full functionality of OctaneRender™ standalone inside Maya®. Materials from the Live DB are currently not available.
HOW TO PURCHASE LICENSES
You can purchase both the OctaneRender™ Standalone Edition and the OctaneRender™ for Maya® Edition as a reduced price bundle, purchase the bundle priced at 279€
Purchase an "OctaneRender™ for Maya® Beta License" priced at 99€
You can also purchase a 3, 5 or 10 pack of OctaneRender™ for Maya® licenses,
just like OctaneRender™ Standalone Edition packs.
OCTANELIVE
  • Fixed the crashes of scenes having image textures.
  • Added "soft thresholds" to some post-processor values...
DOWNLOAD
OctaneRender for Maya v1.17 beta (35.6MB autoinstaller file)
Yours,
The OctaneRender™ Team.
TBFX
Thanks JimStar, Texture problem seems to be fixed.
T.
MTECH
Thanks for the quick turnarounds, JimStar. However, I'm able to enter hypershade now without an instant crash, but scrolling up and down through my materials after working in the scene for a minute or so still causes crashes. Instead of a Fatal error message, it immediately goes to the Windows 7 message "Maya 2013 has stopped working", and I get an Autodesk crash report prompt. It might just be because this scene has seen several revisions of the Octane for Maya plugin but it seems highly and randomly volatile...
Core i7 920 | 12 GB RAM | Nvidia GTX 470 & 260 | Win Vista x64 | Maya 2012.5 x64 | Octane beta2.57
ciboulot
Hi, it looks like the crashes I get with some scenes.
I already talked about this to Jimstar (post: "wierd Maya crashes")
If you get a solution or a turnaround, tell me.
Fred
Laptop HP 8760w, I7, 16Go ram, Quadro fx3000m, Maya 2014, Octane 1.20a. Vimeo: http://vimeo.com/ciboulot/albums
TBFX
Yes the hypershade is still causing crashes for me too. Sorry hardly ever go to the hypershade anymore so didn't notice, the node editor doesn't seem to cause crashes. I've attached a crash dump.
T.
dumpdata_130613.zip
(56.38 KiB) Downloaded 274 times
Thank you for reports.
I will investigate the problem...
TBFX wrote:Yes the hypershade is still causing crashes for me too. Sorry hardly ever go to the hypershade anymore so didn't notice, the node editor doesn't seem to cause crashes. I've attached a crash dump.
T.
Something strange goes here... Regarding your crashes...
As there is no Octane plugin module in the callstack of your crash-dump.
And so far I can't reproduce the crashes with the scene which ciboulot gave me - all works smoothly on my machine with 690 card. Hypershader opens, material previews are shown in them, IPR render works without crashes too... I'm playing with this scene back and forth - no crashes...:?
Can you give me your scene which crashes on your machine, with some description "what should I exactly do to reproduce it"? Perhaps I will be able to reproduce the crashes with your scene...
TBFX
Hi JimStar,
I'm away from my workstation for the day but will have a look over the weekend and test some more to see if I can provide you with more info. I'll also try and get you a scene where it happens. It may not be the one that caused the crash dump i sent though due to size and some rights controlled models.
T.
renmaxhb
I didnot found the crash on my machine.
renmaxhb wrote:I didnot found the crash on my machine.
Thanks for report!
It seems that the difference is in hardware or in the scene itself... The reason why on my machine the same scene does not crash - may be due to this scene is not full, it lacks some of textures and plugins which may cause this crash... I've tried to change the texture paths of ciboulot's scene to my texture files - but so far can't get a crash...
Return to “Autodesk Maya”
