oops! sorry. my reply is too late.
Ok. i want to No.2.
SoftImage XSI Plugin v1.022d
Sorry, My English is bad..
i7 860 | Ram 4GB | Geforce GTX260 Core 216 | Win7 64x Kor | Octane with Softimage 2011 for x64 , ICE
It seems that I loose the connection to the oct-file.
1. I create a scene and use the exporter.
2. I change the material in Octane and then save & quit
3. Back in Softimage I press render once again and all the material-settings are gone in Octane. (If I reload the scene inside Octane everything is fine)
Does anyone else have this problem?
All have this problem.
You must use a material macro for every material in your scene. After reload in Octane, it works.
face
face
http://vimeo.com/user2509578
Some scenes, that works. Others it doesn't.face wrote:All have this problem.
face
Now it works, but I did nothing different and now everything seems ok. If I figure out what it was, I'll post the problem and hopefully the solution.
Ryzen 5950x
128GB Ram
RTX 3070 x 3
128GB Ram
RTX 3070 x 3
Face, can you help me? I keep running into big crashing problems when switching to Octane from XSI. Sometimes a scene that worked great will suddenly crash Octane, or give me that nodegraph assertion error. Is that error related to something done in XSI, or is it Octane's bug? I'm shading my objects at the partition level.
I'll post a scene if needed.
Ryzen 5950x
128GB Ram
RTX 3070 x 3
128GB Ram
RTX 3070 x 3
I get the nodegraph error, if i connect non material macros in and reload the scene.
You must create a material macro, double click on it and connect you material (glossy, diffuse, specular) in the output pin.
After that you can connect your material macro in you mesh.
face
face
So what you are saying is, when just a base material is plugged in to the mesh, it becomes unstable. When the desired material is inside a "material macro" it works.face wrote:I get the nodegraph error, if i connect non material macros in and reload the scene.
face
Ryzen 5950x
128GB Ram
RTX 3070 x 3
128GB Ram
RTX 3070 x 3
Hey face, I haven't been here for a while but I can see you're still cracking. great work !
Maybe I missed it but when do you plan to release a version for XSI v7 or v6.5 ? can't wait to have my hands on it
Win7 Pro x64 | GTX 770 2GB + GTS250 512Mb | Intel Xeon i7 4x 3.4ghz | 16 GB ECC Mem | Intel SSD 520 | Dell 27"
SOFTIMAGE l 2011 + OCTANE V1.20
First, release strands for 2010+ (near)
Second, the same for 7.0 & 7.5
Third, integration the scene scaling for 6.5 - 2011.5
face
face
