I have not yet got any news from engine-team regarding this...
So far it may be helpful to get some detailed info about it from those who has this problem - to I can try to understand the difference between the systems setups (or user actions) in comparison to those who does not have these problems (I can't reproduce it too). So as much details as possible may be helpful - all versions infos, GPUs, actions sequence, screenshots, etc etc...
You may also look in the "c:\Users\<User name>\AppData\Roaming\" folder to see the folders containing Octane license info, named "OctaneRender" or "Refractive Software" - the latter one was used by old versions of OctaneRender, so may be some inconsistency between the new Octane SDK and old standalone license info... You may even try to deactivate Octane on this machine, delete these folders, and then activate again...
Anyway - the more detailed information will be posted, the faster the reason may be found...
Batch Render -- different issues?
I deactivated both accounts, deleted those directories, re-installed both, waited to re-activate them, and then did a VERY, VERY barebones test batch render -- which still yielded the same results:
"12/14/2012
Starting "D:\Program Files\Autodesk\Maya2012\bin\mayabatch.exe"
Octane data types are registered...
Octane nodes are registered...
Octane settings store is registered...
Octane settings instance is created...
Octane camera is registered...
Octane tool shelf commands are registered...
Starting Octane engine...
Octane UI is registered...
...done in 0 min. 7 sec.
Error: line 1: Error starting Octane engine: This account is currently activated on another machine. Please deactivate it on the other machine first and wait 30 minutes before re-activating it on this machine, or activate another account/license on this machine.
Error: line 1: Error activate Octane engine: This account is currently activated on another machine. Please deactivate it on the other machine first and wait 30 minutes before re-activating it on this machine, or activate another account/license on this machine.
File read in 7 seconds.
Result: G:/projects/ipi_contest/jungle_chase/renders/batch_test/scenes/tester__5564.mb
Error: OctaneRender is not activated!
Error: Scene G:/projects/ipi_contest/jungle_chase/renders/batch_test/scenes/tester__5564.mb failed to render.
// Maya exited with status 210"
I am on an 860 (1156) i7, 2.8ghz
16gb ram
2x msi twin frozr III 448-core 560's
1x msi 240 (for display only)
win 7 64 bit
maya 2012 64 bit
octane 64 bit (1.0 release)
maya plugin (newest release)
I made a new project with just a sphere with a octane material, an animated octane camera, and an octane daylight setup. camera keyframed over 24 frames, set to output an image sequence.
Aside from that, I can't think of much else to report...the project is pretty much as basic as it can get, I think. Set my project & made the default folders, so everything should be in place. IPR works fine.
Main drive is an SSD (just OS and minor stuff)
maya is on D: separate disk
I'll attach a screenshot, but it's stuff I think you've already seen before.
Any chance I can at least get some older working beta versions? Would be wonderful to be able to batch...I'm falling quite behind on some of these animations.
Thank you!
John
"12/14/2012
16gb ram
win 7 64 bit
maya 2012 64 bit
Thank you!
John
Thanks for info!
Is it exactly what you have copied from log-file, of have you edited something in the sequence of lines? As some things here looks strange...johnb4467 wrote:Starting "D:\Program Files\Autodesk\Maya2012\bin\mayabatch.exe"
Hmm, hopefully "strange" as in "this could be helpful..."?
To make sure I didn't change anything accidentally, here's the mayaRenderLog.txt as an attachment.
Oh, nevermind...text files not allowed.
hmm, ok let me try and paste it in again.
What in particular seemed strange?
paste starting below this line from notepad...
12/14/2012
12/14/2012
johnb4467
Thank you.
No, I see that this "strange" is another thing - Maya's weird API behaviour in script console output sequence... No relation with this activation bug.
We still should wait for it will be fixed in Octane engine...
Thank you.
Hello, Octa-people!
Happy New Year!
I've recently purchased Octane and was ready to lunch my first butch render.
But... there was the same trouble:
_________________________________________________________
Starting "C:\Program Files\Autodesk\Maya2012\bin\mayabatch.exe"
mental ray for Maya 2012
mental ray: version 3.9.1.36, Feb 2 2011, revision 138829
File read in 0 seconds.
Result: E:/2.MAYA/scenes/RF_bn__800.mb
Error: Scene E:/2.MAYA/scenes/RF_bn__800.mb failed to render.
Frankly, that a kind of issue makes my workflow problematic... and I would be very grateful for your any help that could resolve the problem. Someone knows another way to render in Octane an image sequence from Maya?
I have a realflow mesh, Octane camera and octane Light in my scene.
Thanks in advance.
Happy New Year!
Thanks in advance.
Win 7 x64, i7 3930k, 32GB, 2x gtx590, 1x gtx580, Octane Render + Maya plugin v1.02a, nVidia driver 310.70
focus
This it the known issue, we are trying to find the reason...
The problem is only few users have it, so the difference is somewhere in your system setup. And to be able to catch the issue it will be helpful to find what this difference is... E.g. have you the last version of NVidia drivers installed? Have you tried to run the plugin on another machine?
Thank you for your reply.
Suppose that we are few to use the latest releases of Octane Render with Maya and latest Maya plugin.
In spite of this fact I hope that a fast fix will be shortly made.
I have a new freshly installed machine.
I run on:
____________________________________________________________________________
OS Name Microsoft Windows 7 Ultimate
Version 6.1.7601 Service Pack 1 Build 7601
Other OS Description Not Available
OS Manufacturer Microsoft Corporation
System Name XXXXXXX
System Manufacturer MSI
System Model MS-7737
System Type x64-based PC
Processor Intel(R) Core(TM) i7-3930K CPU @ 3.20GHz, 3201 Mhz, 6 Core(s), 12 Logical Processor(s)
BIOS Version/Date American Megatrends Inc. V1.3, 4/13/2012
SMBIOS Version 2.7
Windows Directory C:\Windows
System Directory C:\Windows\system32
Boot Device \Device\HarddiskVolume1
Locale United States
Hardware Abstraction Layer Version = "6.1.7601.17514"
User Name XXXXXXXXXXX
Time Zone Romance Standard Time
Installed Physical Memory (RAM) 32.0 GB
Total Physical Memory 32.0 GB
Available Physical Memory 24.8 GB
Total Virtual Memory 33.9 GB
Available Virtual Memory 19.7 GB
Page File Space 1.95 GB
VIDEOCARDS: 2 x gtx590, 1 x gtx 580
SOFTWARE:
Name Version
Autodesk 123D Catch 1.0.248
Qualoth 3.1.6
Autodesk Revit Interoperability for 3ds Max and 3ds Max Design 2013 64-bit 1.0.0.1
Microsoft_VC90_MFCLOC_x86 1.00.0000
QuickTime 7.73.80.64
Microsoft Visual C++ 2008 Redistributable - x64 9.0.30729.4148 9.0.30729.4148
Microsoft_VC90_CRT_x86 1.00.0000
Composite 2013 64-bit 8.0.0
Microsoft Visual C++ 2010 x64 Redistributable - 10.0.40219 10.0.40219
Microsoft Visual C++ 2005 Redistributable (x64) 8.0.61000
Microsoft Visual C++ 2010 x86 Redistributable - 10.0.40219 10.0.40219
Maxwell Shell Extension (x64) 2.7.0
Autodesk Material Library 2012 2.5.0.8
Adobe AIR 3.1.0.4880
Composite 2012 64-bit 7.0.0
Microsoft Visual C++ 2005 Redistributable 8.0.59193
AVG 2013 13.0.2637
True Image 2013 16.0.5587
bl 1.0.0
Autodesk Maya 2012 64-bit 14.0.0.0
Autodesk Material Library Medium Resolution Image Library 2012 2.5.0.8
Turtle for Maya Premium 2012 64-bit 5.3
ph 1.0.0
Adobe Widget Browser 2.0.348
Sentinel Protection Installer 7.4.0 7.4.0
Asmedia ASM106x SATA Host Controller Driver 1.2.1.000
Autodesk DirectConnect 2012 64-bit 6.0.443.0
Adobe Acrobat X Pro - English, Français, Deutsch 10.1.4
Adobe Reader XI 11.0.00
Smedge 2012 12.2.240
Visual Studio 2010 x64 Redistributables 13.0.0.1
PDF Settings CS6 11.0
Apple Application Support 2.3
Microsoft Visual C++ 2005 Redistributable (x64) 8.0.56336
Autodesk 3ds Max 2013 64-bit 15.0.0.347
Autodesk 3ds Max 2012 64-bit - English 14.0
Java(TM) SE Runtime Environment 6 Update 6 1.6.0.60
Renesas Electronics USB 3.0 Host Controller Driver 2.0.34.0
AVG 2013 13.0.2805
NVIDIA PhysX 9.12.1031
VC90_CRT_x64 1.01.0000
Microsoft_VC80_CRT_x86 8.0.50727.4053
Autodesk MatchMover 2012 64-bit 14.00.0000
Autodesk Material Library Base Resolution Image Library 2013 3.0.13
Autodesk Material Library Base Resolution Image Library 2012 2.5.0.8
Microsoft Visual C++ 2005 Redistributable (x64) 8.0.59192
Adobe Help Manager 4.0.244
Microsoft Visual C++ 2005 Redistributable 8.0.56336
Microsoft_VC90_MFC_x86 1.00.0000
License Support 1.1.0.0929
Visual C++ 64-bit Redistributables 1.1.0.0929
Autodesk Material Library 2013 3.0.13
MacDrive 8 8.0.5.31
Microsoft Visual C++ 2005 Redistributable 8.0.61001
Microsoft .NET Framework 4 Extended 4.0.30319
Autodesk Inventor Server Engine for 3ds Max 2013 64-bit 15.0
Autodesk Material Library Medium Resolution Image Library 2013 3.0.13
Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.4148 9.0.30729.4148
Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.17 9.0.30729
Visual C++ Redistributables 1.1.0.0929
Autodesk Backburner 2012.0.0 2012.0.0
Microsoft Silverlight 5.1.10411.0
16.7.0.0
Microsoft .NET Framework 4 Client Profile 4.0.30319
Microsoft Visual C++ 2008 Redistributable - x64 9.0.30729.17 9.0.30729
VC_CRT_x64 1.02.0000
NVIDIA PhysX Plug-in for Autodesk Maya 2012 64 bit 2.60.0216.1828
MAYA START LOG.
_____________________________________________________________________________
file -f -new;
// Warning: Active stereo does not work with Aero enabled. Active stereo has been disabled. //
// untitled //
commandPort -securityWarning -name commandportDefault;
// Octane data types are registered...
// Octane nodes are registered...
// Octane settings store is registered...
// Octane settings instance is created...
// Octane camera is registered...
// Octane tool shelf commands are registered...
// Octane scene translator is registered...
// Starting Octane engine...
// Octane plugin is activated.
// Octane materials LiveDB swatches refresh started...
updateRendererUI;
// Octane UI is registered...
// ...done in 0 min. 4 sec.
// Maxwell: listing extensions: //
// Maxwell: texture extensions: //
// Maxwell: found 0 texture extension(s). //
// Maxwell: geometry modifier extensions: //
// "MaxwellCloner" //
// "MaxwellGrass" //
// Maxwell: found 2 geometry modifier extension(s). //
// Maxwell: geometry loader extensions: //
// "MaxwellMesher" //
// "RFMeshes" //
// "RWMeshes" //
// Maxwell: found 3 geometry loader extension(s). //
// Maxwell: procedural geometry extensions: //
// "MaxwellHair" //
// "MaxwellParticles" //
// "MGrassH" //
// "MGrassP" //
// Maxwell: found 4 procedural geometry extension(s). //
// Maxwell: sky extensions: //
// Maxwell: found 0 sky extension(s). //
// Maxwell: scene modifier extensions: //
// Maxwell: found 0 scene modifier extension(s). //
// Maxwell: found 9 extension(s) in total. //
updateRendererUI;
updateRendererUI;
I hope it should be helpful for you, dear JimStar, to try to determine the issue causer.
I'm just impatient to see a new release of fully working Maya plugin for Octane.
I run on:
System Name XXXXXXX
SMBIOS Version 2.7
SOFTWARE:
Name Version
Qualoth 3.1.6
AVG 2013 13.0.2637
bl 1.0.0
ph 1.0.0
AVG 2013 13.0.2805
MacDrive 8 8.0.5.31
16.7.0.0
MAYA START LOG.
file -f -new;
// untitled //
updateRendererUI;
// "RFMeshes" //
// "RWMeshes" //
// "MaxwellHair" //
// "MGrassH" //
// "MGrassP" //
updateRendererUI;
updateRendererUI;
I have been doing some trouble shooting on this issue and found a few things that might help.
I tried maya 2012 and 2013 neither Batch rendered.
Using OctaneRender_1_00_win64.exe and OctaneRender for Maya 2.58m beta batch render works. This leads me to think that it may be the plugin and not the engine. I would test with more versions but that is all I can get my hands on.
