Wrong orintation on ICE particle instance
Autodesk Softimage XSI (Developed by Face)
face
Have spend some time and find an error in the 2011 SDK.
To set a quaternion, the SDK write, set it with quat.set(doubleW, doubleX, doubleY, doubleZ). But it must set with quat.set(doubleX, doubleY, doubleZ, doubleW).
In the 2013 SDK the issues is solved, maybe in the 2012SDK also.
Hope it works now...
face
Octane2011.zip
(182.47 KiB) Downloaded 380 times
http://vimeo.com/user2509578
wilson66
now it works. thanks a lot...
Jack-Jack
Thanks face!!!
Win7 x64, 12GB Ram, i7 970 3,2 GHz,
GTX590 3GB
Softimage 2013 & Octane 1.025 beta 2.57
Soft2Octane v1.0252c Win
Laurent75
Hi Face !
I'm using the new version 3.03 for few days now (SI 2013, Octane RC03, Soft2Octane 3.03, Win 7 64)
I'm afraid I'm experiencing the exact same pb about particule instance orientation as discussed in this forum thread.
I download the zip file, about the Octane2011.dll, but is it compliant with the latest Soft2octane 3.03 distribution ? (you were saying we have to replace the old Octane2011.dll file ..., but I don't find it :-( )
Thank you for your great work with Soft2Octane ! :-)
Gescort
Instances not render, please help. Softimage 2014.
And Soft2Octane error, open Octane without instances. Put log image + debug log.
But export files are created, manually created scene has wrong instances position.
face
You must create the Octane scene by hand and save they.
After that, there is an option in the export settings where you can type in a mesh/group to render.
There should be the name from the group from the Octane scene.
About the position, the instance shape should be at 0,0,0.
When the shape is on 0,0,0 and the geometry begins at 10,0,0, the output is correct.
To solve this, set the center of the shape to bounding box and recenter the mesh to 0,0,0.
face
Gescort
Thanks, now is OK.
Return to “Autodesk Softimage XSI”
