The world's fastest and most feature-rich unbiased render engine that integrates completely into Autodesk® 3ds max®.
This version is not stable, don't use for important projects.
3ds max® Version Requirements
This release will only work with 3ds max® Versions 2010, 2011, 2012 & 2013/ 32bit & 64x / Base & Design on MS Windows operating systems.
Notes regarding features/functionality
OctaneRender® for 3ds max® implements all functionality of OctaneRender® standalone inside 3ds max®.
Any feature that the Standalone edition supports is supported by the 3ds max® plugin.
To run OctaneRender® for 3ds max®, you need to also have an activated OctaneRender® Standalone copy activated on the machine you wish to install the plugin onto.
You cannot purchase and use only the 3ds max plugin and use it without also owning an activated copy of OctaneRender® Standalone on your machine.
HOW TO PURCHASE LICENSES
Go to our online shop here: http://www.refractivesoftware.com/shop/
If you do not own an OctaneRender® Standalone Edition License yet:
You can purchase both the OctaneRender® Standalone Edition and the OctaneRender® for 3ds max® Edition as a reduced price bundle, purchase the bundle priced at 179€
If you already own one or more OctaneRender® Standalone Edition licenses you want to pair the plugin with:
Purchase an "OctaneRender® for 3ds max® v1.0 Beta License" priced at 99€
You can also purchase a 3, 5 or 10 pack of OctaneRender® for 3ds max® licenses,
just like OctaneRender Standalone Edition packs.
INSTALLATION INSTRUCTIONS
At this moment there isn't automatic installation. You have to copy files to 3ds max manually.
Please read the installation text file included in the download ZIP file archive.
OCTANELIVE®
Just like OctaneRender® Standalone, The 3ds max® plugin product also needs an additional octanelive license and be activated on a machine.
This has to be done in the plugin interface panel in 3ds max, and is covered in the included PDF manual.
It can only be done after an OctaneRender® Standalone license is already activated on the machine in question.
NEW FEATURES SINCE LAST RELEASE:
- Instancing. To set object as instance, do right click on it, select Octane properties, set movable proxy option.
- Falloff texture
- Color correct texture
- Incorrect lighting distribution (random bug).
- Incorrect material preview in case render is not running.
- Slow render on 3dsmax 2013
- Don't support old GPU models.
DOWNLOAD
We have 4 separate archives available for download, for Autodesk® 3ds max® 2010, 2011, 2012 and 2013.
Each archive contains the manual and installation text file, and both 32bit and x64 versions of the plugin,
so you only need to dowload one archive for your 3ds max® version from the following download links:
3ds max® 2010: http://www.refractivesoftware.com/plugi ... a_3.00.zip (50MB ZIP File)
3ds max® 2011: http://www.refractivesoftware.com/plugi ... a_3.00.zip (50MB ZIP File)
3ds max® 2012: http://www.refractivesoftware.com/plugi ... a_3.00.zip (50MB ZIP File)
3ds max® 2013: http://www.refractivesoftware.com/plugi ... a_3.00.zip (50MB ZIP File)
Yours,
The OctaneRender® Team.
