I listen to the conversation with great interest. Don't stop to blind us, Gabriele.
pt vs pmc
+100
very nice and clean, the light behind the mirrors are great, I was having trouble with something like that, you are using large plane lights?
how long did it take you to set up the lights and bumps
I can see your take on the vray - it tends to have that certain plastic look, I guess octane has one now - warm and diffuse
how many textures per map are you using - like on that grey wall, I always go with a cheap option of setting up bump and a slight glossy, this one looks like there's a specular texture and a diffuse texture along with a bump or a normal texture?
3dmax, zbrush, UE
//Behance profile //BOONAR
- gabrielefx
yes large octane planar lights with 3 different colors: white, slight orange, slight cyanacc24ex wrote:very nice and clean, the light behind the mirrors are great, I was having trouble with something like that, you are using large plane lights?
I donno how many maps I use, in Max you have the textures inspector and you can count them.
The gray wall is a two color texture mixed with a mask, bump, ref and specular map.
I instance all textures. For example specular is instanced on reflection but mixed differently.
I never use normal maps except for stone wall textures or when I miss a displacement tool.
I thought it was not compatible with 3dsmax plugin.. if I try to use Hair & Fur the renderviewport won't start..how did you do it?gabrielefx wrote:thank you,Pullakk wrote:Amazing as always.
How did you do that carpet...that must be modeled.
it's Max fur
edit: found it..convert to mesh ; )
Win 7 64 | 2 X MSI AERO GtX 1070| Intel I7-6850K| 32 GB DDR4 RAM | Asus X99 II-A
