A question on the possibility of moving objects
kavorka
Now, correctly if I'm wrong, but instancing will allow us to also move objects in the scene. Maybe not at first, but the possibility is there. I am assuming this is true.
If this gets implemented, will it be possible to have a second viewport where we can move our camera and move objects while seeing how the change looks in our main camera? Best example is for lights, if the light mesh is off the scene, I currently wont be able to move it around and see how it affects the scene without moving my camera. Now, if this is possible, it would probably be a good idea to have a traditional CPU rendered viewport for the second one so it doesnt slow down the actual rendering. Or, if thats not possible, have the option to have each viewport rendered by separate cards, then when you render, you switch to one view and all GPUs.
Let me know if my heads in the clouds here.
roeland
We don't know yet, we will first finish instancing and then see what we can do next.
Roeland
tyrot
kavorka my friend :) you are not the one who has clouds:)
If i decipher Roeland correctly - THAT IS NEXT :)
We will move even our CLOUDS in octane after instancing i believe that is next..
kavorka
I figured that was the next game plan, I really just wanted to put the multiple viewport idea out there so it's in their heads (if they didnt already consider it) when planning movable objects.
Q-Games
Btw kavorka, if you create a Render Target node, you don't have to worry about moving the camera. You can create multiple camera nodes and attach them to the Render Target node, so for instance, you can have a camera node to use as test camera, so you can move around in the scene, adjust the lights etc. and another camera node for the final render. You can have as many camera nodes as you want.
Intel Core i7-2600 CPU @ 3.40GHz | RAM 16GB DDR3 | GeForce GTX 480 Core 405 MHz | Win7 64bit Jap
kavorka
but that doesn't solve the problem of moving an off camera light while still seeing how it will change the the scene from that cameras view.
Q-Games
Why not? You can switch camera at any time, I don't see the problem.
kavorka
I want to have both up at the same time so I can see the changes in my camera's view WHILE I move the light source, not having to go back and forth.
