Octane Render Commercial v1.02 beta2 Released
understand
this rocks!!!
(i hate the new UI :? )
Win 8.0 64-bit | Gainward 460 GTX 2048mb (driver: latest) | Phenom 965 3.4ghz 140w | 12GB
Win 8.1 64-bit | EVGA 780ti Superclocked 3072mb (driver: latest) | i7 4930k 3.4ghz | 32GB
Win 7 64-bit Bootcamp | 650M 1GB (driver: 327.23) | i7 2.7ghz | 8GB
ROUBAL
I agree that the GUI is not as good as the previous one : the behaviour of the buttons to enable disable the render, the material picker and the Autofocus features is very weird and counter intuitive. Visually it is not obvious and it is not easy to see at first glance what is active or not.
@Radiance : please in beta 3, could you come back to the previous system ?.
tonno
hey
i try to instal in my mac but the license key that i keep the octane said is wrong..... why???
someone can hel me please :D :D
Nostromo
tonno wrote:hey
Try running octane under an administrative account the first time, just in case file system permission prevents it to write the license file where it should be. Also, are you sure the key has been generated for the machineID displayed in the box ?
/M
tonno
hi
octane that I put in windows with bootcamp is work, the license key is always that?
now I try to uninstall Windows octane and see what happens in my mac, none of these problems?
thanks
Nostromo
I'm not sure I understand exactly your problem... could you be more specific ?
/M
tonno
hi thanks for help me.....
sorry for my bad english i try to explane
so i install the previously version of ocatne in windows via bootcamp with a license key and evertihnk works graet !!!
now i instal the mac version of octane and i use the same license key (is that ok???) but the program said invalid key....
i hope i explane well so you understand...
thanks again
Nostromo
Please check if the software reports the same machine ID for both bootcamp and mac. If it does, the software should run with the same license key. But it is possible the two os will report a different one. In that last case, you should choose one of the two as your work operating system.
/M
tonno
hi thanks for the aswer....
i see that the machine id is different in the last letter.....i send all to license refractive..... i hope someone aswer to me
thanks again
pixym
radiance wrote:
pixym wrote:Anothere issue while opening OCS with an modified obj (without no modified material):
- Materials change, for example what was previouly "Mat A" become "Mat B" etc.
you don't do that...
you load the OCS, and relink the new OBJ with the relinking button, at the end of the meshnode,
in a similar way than reloading a different image in an image texture node...
Radiance
Ok I did not know that, thx for the tip.
Work Station : MB ASUS X299-Pro/SE - Intel i9 7980XE (2,6ghz 18 cores / 36 threads) - Ram 64GB - RTX4090 + RTX3090 - Win10
Net render : MB Asus Pro WS W790E-SAGE SE - XEON - 128GB - 2 x RTX 3090 - 3 x RTX 2080TI
Return to “Commercial Product News & Releases (Download here)”
