Rhino OS X issues
mfe
Hello,
I was wondering if anyone had created a functional workflow for Rhino OS X. Any time I try to export to obj from rhino I end up with odd things happening in Octane (such as only every other triangle showing up or surfaces getting randomly stretched to specific points as seen in the images below). Any advice is hugely appreciated.
Mike
This is what it looks like when opened in Octane
This is what the obj looks like when opened in Rhino OS X
This jacket only half showed up
SamPage
If you round trip that OBJ back into Rhino, what does it look like?
Win 7 64bit | 2x GTX 285 | i7 920 | ASUS P6T Deluxe | 12GB
SamPage
Doh, sorry, didn't read your captions. Can you post the exported OBJ?
mfe
Hello,
Thanks for the quick response. I cannot seem to attach the larger obj file, but here is a copy of just the jacket on the stand and there appear to be similar issues (even though the jacket seems to be working more nicely, the stand is now messed up).
Thank you,
Mike
This is what it looks like in Octane (exported with less polygons)
Example 2.obj.zip
Here is the larger scene
(3.19 MiB) Downloaded 285 times
Example 1.obj.zip
Here is the file zipped up
(913.71 KiB) Downloaded 294 times
Certain parts of the stand appear to be connecting surfaces where they should not be.
mfe
Here is what I figured out. If you export to obj with the "End-of-line Characters" set to "windows (CLRF)". I am not sure exactly what this means, but I know that when I do this the models turn out perfect. Spread the word far and wide, mac rhino has an unbiased rendering engine! I am very excited to start rendering everything in Octane.
Thanks so much!
Mike Egan
Here is a similar scene to the one that was messing up earlier brought in with the one setting changed
Here are the export settings that worked.  You can see that the End-of-line Characters were set to Windows (CLRF)
Return to “Rhinoceros 3D”
