New gtx 680
Forums: New gtx 680
Re: New gtx 680
Postby t_3 » Fri Mar 23, 2012 12:19 am
t_3 Fri Mar 23, 2012 12:19 am
there is also this chart:
fma32 performance 1.5 / 2.0 8-)
if octane can take full advantage of this, it'll be great news for all octaners...
*starts drooling uncontrolled*
:D
EDIT: oh, and there is thisss:
Image (the blue bars of course)
sources:
http://www.brightsideofnews.com/news/20 ... x?pageid=1
http://www.brightsideofnews.com/news/20 ... x?pageid=4
t_3
Re: New gtx 680
Postby t_3 » Fri Mar 23, 2012 1:49 am
t_3 Fri Mar 23, 2012 1:49 am
ok. ordered one & will have it in a few hours. next info will be if it is at all working in octane with the current cuda build, and if not out of luck, some scores ;)
t_3
Re: New gtx 680
Postby MEC4D » Fri Mar 23, 2012 1:55 am
MEC4D Fri Mar 23, 2012 1:55 am
OK ... I am waiting for the result with octane .. I tried to order one but was already out of stock here .. it did not last even half day ...
MEC4D
Re: New gtx 680
Postby elwisoroarke » Fri Mar 23, 2012 3:05 am
elwisoroarke Fri Mar 23, 2012 3:05 am
Jaberwocky wrote:Ok Guys.
Just picked this snippit of info out for those running out of textures on a scene
Quote
Now that the number of texture units doubled, NVIDIA also changed the way how Texture Units operate. In the pre-Kepler era, you could use up to 128 simultaneous textures. Bindless Textures are probably the key reason why Samaritan can run on a single card, and why the performance of GT 640M and GTX 680 is where it is. This feature increased the number of simultaneous textures from 128 to over a million. Yes, you've read this correctly. An engine developer can now run its shader code on all the textures he or she plans to use and run those textures as they come along. In ideal circumstances, Samaritan demo can address operations on 200-300…1000 textures and Kepler gives you that level.
:shock:
I picked it up out of this review
Link
http://www.brightsideofnews.com/news/20 ... x?pageid=2
Interesting
Texture problem solved ? :o
:shock: :shock: indeed if this can be accessed by Octane in the next builds. Add instancing & displacement support & it's practically ready for Prime Time! :D
Win7|i7Quad @2.9hz|16gb|GTX 470
"I've seen the future & it will be, I've seen the future & it works"
"3 things cannot be long hidden: the moon, the sun, & the truth"
"Light glorifies everything...light is everything.”
elwisoroarke
Re: New gtx 680
Postby elwisoroarke » Fri Mar 23, 2012 3:08 am
elwisoroarke Fri Mar 23, 2012 3:08 am
MEC4D wrote:OK ... I am waiting for the result with octane .. I tried to order one but was already out of stock here .. it did not last even half day ...
Which means the 5XX series will drop like easter eggs from the bunny LOL, I've already seen the mid priced 2GB 5XXs begin to dive. So if you're on a budget it's gonna be a good time to pick up an extra card or two (if you mobo supports multi PCIe 2.0 cards).
Of course if my next couple of web clients pay on time & quickly...I might be able to give myself an Easter treat!
elwisoroarke
Re: New gtx 680
Postby nildoe » Fri Mar 23, 2012 8:52 am
nildoe Fri Mar 23, 2012 8:52 am
i just paid for one over at ebay...but only on apr9th to apr13th i will get it! :) :) :)
Nildo
Corei7, 6x GTX1070 (2 Inside and 4 in a CUBIX Xpander), 32GB Ram, Win10 64Bit Home, 3dsMax2017 64Bit, Octane for max 3 and LOVING IT!!!!
MSI GT72S 6QE Dominator Pro G win10Home, gtx 980m.
nildoe
Re: New gtx 680
Postby nildoe » Fri Mar 23, 2012 9:25 am
nildoe Fri Mar 23, 2012 9:25 am
Hi Guys...
a little help please...
the gtx 680 its said to have a BUS INTERFACE of PCI Express 3.0
will my MBoard the gigabyte X58A-UD7X, support this card? i'm having trouble understanding the following info from manufacturer website:
Expansion Slots
2 x PCI Express x16 slots, running at x16 (PCIEX16_1/PCIEX16_2) (Note 2)
2 x PCI Express x16 slot, running at x8 (PCIEX8_1/PCIEX8_2) (Note 3) (The PCIEX16_1, PCIEX16_2, PCIEX8_1 and PCIEX8_2 slots conform to PCI Express 2.0 standard.)
2 x PCI Express x1 slots
1 x PCI slot
do you think i'll have issues? right now im running 2 gtx480 with this board with NO issues (except some minor heat excess when rendering).
Nildo
nildoe
Re: New gtx 680
Postby pixelrush » Fri Mar 23, 2012 10:04 am
pixelrush Fri Mar 23, 2012 10:04 am
Yes it will run fine.
PCI-e is backward compatible. The bus will run at pci-e 2.0 speeds rather than 3.0.
It will just take a little bit longer to load your scene than if the mobo was pci-e 3.0 as well = no change for you but the actual rendering will be faster of course.
You can actually get 3 double slot cards in that mobo if they will fit in the case.
You need to look out for cooling issues with closely spaced cards though.
When you have more than 2 cards in there the bandwidth is shared between slots as per the notes.
They go from 2@16x + 2@8x to 4@8x, again really a non issue for Octane.
HTH :geek:
i7-3820 @4.3Ghz | 24gb | Win7pro-64
GTS 250 display + 2 x GTX 780 cuda| driver 331.65
Octane v1.55
pixelrush
Re: New gtx 680
Postby nildoe » Fri Mar 23, 2012 10:26 am
nildoe Fri Mar 23, 2012 10:26 am
Ouf..thx alot pixelrush...
that helped understanding alot..
so i can really stick 2 or 3 cards in with no issues? other than heat of course...
mann...this is like a dream :).
Nildo
nildoe
Re: New gtx 680
Postby pixelrush » Fri Mar 23, 2012 10:38 am
pixelrush Fri Mar 23, 2012 10:38 am
Yes, a GTX680 should be about twice as fast as a GTX480 and consume ~55W less each, be quieter and cooler, plus they have 2 or 4 gb instead of 1.5gb. 8-)
If Kepler do allow more than 128 textures, well its an easy sell to Octaners, isn't it? :)
Octane v1.55
pixelrush
PreviousNext
Return to Demo Version Questions & Discussion
Users browsing this forum: Bing [Bot] and 5 guests
Thu May 23, 2024 5:23 am [ UTC ]
