Here is a quick overview of what will be available with next Octane beta.
Water is made with bump
Trees, plants and leaves made using opacity maps (except background which is an image).
Original in 1024x800 rendered in about 22 min
Edit : Forgot to mention, it's lit with an hdr map
Ok let's begin with serious things ...
- enricocerica
- Contact:
Modeling system : I7 32GB Windows 10 & Fujitsu Celsius H720
GPU : 1x Gigabyte GTX580 3GB + 1x MSI GTX780 3GB + 1x PALIT GTX780 6GB +1x Asus Stix GTX1070 8GB
http://www.myline.be
Your topic name cracked me up
Good scene, the water is very cool looking (almost green, like natural water, not blue-ish pool water)
Nice vegetation, details (like the leave in the foreground + on the water)
The background fit perfectly the scene
10/10 !
10/10 !
http://Kuto.ch - Samuel Zeller - Freelance 3D Generalist and Graphic designer from Switzerland
Agree, its like the left part was directlighting and the right part was pathtracingjust the reed plants on the left back are a bit dark
I need to adjust my rating to something like
9.8/10
Hi enrico. Nice image:) Did you use diffuse transmission for umbrella material?
Cheers,
n1k
Cheers,
n1k
very nice still, but some direct lighting would be welcome.
Work Station : MB ASUS X299-Pro/SE - Intel i9 7980XE (2,6ghz 18 cores / 36 threads) - Ram 64GB - RTX4090 + RTX3090 - Win10
Net render : MB Asus Pro WS W790E-SAGE SE - XEON - 128GB - 2 x RTX 3090 - 3 x RTX 2080TI
- enricocerica
- Contact:
Thanks guys for comments,
n1k:I used the opacity slided to get some transparency
javadevil:yes I noticed that issue, I activated the smooth but it does not solved the problem.
is your bump map resolution large enough ?enricocerica wrote:Thanks guys for comments,
what's the image size ?
Radiance
Sam`s image got the same problem: http://www.refractivesoftware.com/forum ... ?f=5&t=863
Are textures filtered in some way in Octane?
Nice image between, looks very realistic
Cheers
Cheers
________________________________________________________
Win 7 64 | 1x GeForce GTX Titan | AMD Phenom II X6 3.20Ghz | 16GB
