AttributError_Blender 2.62.1 - Bmesh
Piernik
Hi blenders collective!
Did you have the same problem? and what the F@#% is this!
please help me understand this error. :(
Regards.
W7 x64 | GTX560 2X & GTX660 | i7 2600K CPU 3.40GHz | 16GB |
pixelrush
Don't use a mesh build yet. The code for UV isn't done, among other things.
Go back to the official release Blender 2.62 and use script 1.13 found in the post :arrow: [Unsupported] Plugin camera fix for recent Blender builds
i7-3820 @4.3Ghz | 24gb | Win7pro-64
GTS 250 display + 2 x GTX 780 cuda| driver 331.65
Octane v1.55
Piernik
pixelrush wrote:Don't use a mesh build yet. The code for UV isn't done, among other things.
OK. thank you pixelrush for informations.
yoyoz
Guys, can you give a try to attached 1.14?
It should fix the uv exports but not the normals, so disable their export please.
octanerender.v1.14.zip
(61.96 KiB) Downloaded 311 times
Desktop: Ubuntu 13.04 x64 - i7-3770K @ 3.5GHz - 32GB DDR3 - GTX670 2048MB
Laptop: Linux Mint 11 x64 - i7-2860QM @ 2.5GHz - 16GB DDR3 - Quadro 3000M 2GB
Software: NVidia 319.12 - Cuda 4.2.9 - Blender 2.66a
Piernik
yoyoz wrote:Guys, can you give a try to attached 1.14?
Hi yoyoz!
"Completed in 0h0m18.71"
Works fine! :)...and the problems with Normals, you mean "Normals: Flip Direction"?
Regards and thank you yoyoz!
aLeXXtoR
Hi, Lionel!
Thank you for your update! But I got errors — I loaded my complex production scene and got this message:
Blender 2.62 r44639.
Win 10 Pro 64bit | GeForce RTX 2070 SUPER 8Gb | AMD Ryzen 7 3700X | 32GB RAM
WebSite
Showreel
Piernik
Hi aLeXXtoR!
Try to use Blender 2.62.0 r44427.
aLeXXtoR
Hi, Piernik.
Hmm... it seems to be working with r44427, but my Octane (2.57) crashes while parsing vertexes.
Please you try r44639. :)
It seems like there is no use to try implementing export feature until BMesh integration is completed. Newer builds causes new incompatibilities. :(
... but this modelling feature is so cool. )))
WebSite
Showreel
yoyoz
Piernik wrote:...and the problems with Normals, you mean "Normals: Flip Direction"?
Nope, it's just that since bmesh, normals are exported in a different order as before. I've opened a ticket for that so I can see how Campbell fixes it in the wavefront exporter.
aLeXXtoR wrote:Thank you for your update! But I got errors — I loaded my complex production scene and got this message
Quite strange error, as none of the parameters are supposed to be of type 'byte'...
You can try the following:
- upgrade to newer build
- disable verbose logging
[EDIT] I'm also at 44639 at the moment
yoyoz
@aLeXXtoR: issue fixed with new version: http://www.refractivesoftware.com/forum ... 32&t=14875
Return to “Blender”
