Daz2Octane Beta released
Moderator: BK
Jadawyn2011
DS4 64bit 4.0.3.36
Tugpsx
Jadawyn2011 wrote:DS4 64bit 4.0.3.36
Interesting, just did a quick test and was not able to duplicate the error. what is in your scene? how often does this happen?
Surprised that others have not reported this before.
Jadawyn2011
Bare scene, simply Vic5 with Bree textures, nothing else
KaroBastardKiter
Hi guys
I'm net to DAZ Studio and daz2octane.
I have downloaded and installed DAZ Studio 4 but i don't seem to be ablo to find the scripting tool.
Anyone can adress me to the right direction?
Alienware M17x R3 | GTX 460M | Quad 2.0 GHz | 8 GB
Win 7 x64 | Blender 2.59 | Octane
Tugpsx
Jadawyn2011 wrote:Bare scene, simply Vic5 with Bree textures, nothing else
I have done several tests over the past few days and have not gotten that error. Unsure what is causing it for you.
Hopefully should be resolved in next release.
Tugpsx
KaroBastardKiter wrote:Hi guys
Did you install the plugin per the instructions.
Remember you can do a search in DS4 to find installed content
KaroBastardKiter
do I have to install the Script SDK? I see no 'Scripts' menu like you have in your screenshots...
I can't find the one for DS4, apparently it's not out yet, only the one for DS3.
Thanks vm
KaroBastardKiter
got it working!!
thanks!
Sighman
Tug,
Will your plugin 'fix' some of the obj material export issues? All materials get exported (or imported into octane) as difuse instead of glossy or specular and the bump maps are set to 100% instead of using the DS settings. Eyes need alot of tweeking after import and specular maps are not exported at all. I've used your demo (II) and I see no difference between the export the plugin does and the native DS obj export. I noticed that there is a material setup tab in your plugin but it is read only right now. I'm hoping this will be a functional part of your plugin once you release...
Win8/64, I7-4770K (3.5Ghz) 24GB, GTX-980ti (6GB) / GTX-TITAN (6GB)
Tugpsx
Yes. Im actually working on an animation that show that the plugin will set map for eyes and yes Daz2Octane is capable of animation.
Return to “DAZ Studio”
