Applying Textures and how to manipulate the texture
Post, discuss and share handy resources like textures, models and HDRI maps in this forum.
markwong
Hi all,
Im a newbie in 3D. Im trying to texture map my scenes to be render in Octane.
I bought a 3D model from Turbo Squid. The texture maps are all great ( in order where they should be and look )
Refer to my attachment. It did not tile the repeater patterns as suppose to. Why is it so?
When i try to add material and add texture, i find that i cant control when it should be mapped. ( on some cases , it flipped my texture 90degree clockwise. - landscape texture becomes portrait when apply to the OBJ in Octane.
How can overcome this problem?
Any advice ?
Thank for your help.
Best regards
Mark Wong
face
There is no option to map a texture.
You must do it with you 3d app.
face
http://vimeo.com/user2509578
markwong
Thanks Face. Noted.
abreukers
hi folks, let's just move this topic from the wip and place it at the resources and sharing forum (... shadow in place). cheers :)
i72630QM @ 2.00GHz | 6GB RAM | 2GB GeForce GT 540M | Win7 64bit
convergen
You can tile a image texture by using the scale variable on the image node... if you want to be able to scale it independently on the x and y, change the scale from float to float2, that will allow you to give x y scaling options
Convergen | Adelaide Australia
Windows 7 x64 | GTX 580 1.5GB | 12GB DDR3 | Core i7 920 @ 3.6ghz
Return to “Resources and Sharing”
