reading room ( re rendered )
ribrahomedesign
Hi there,
me again , here are the re rendered images with SSS applied to the lampshade
thanks to Beppeg and Kubo .hope you like it .
Rico
Windows 7 , 64 b / GTX 590 / Archicad 15 , 64 b / Cinema 4D R 13 studio , 64b /Intel(R)Core(TM)Extreme3,20Ghz /always latest Octane.
ROUBAL
Nice !
pixelrush
Yeah OK I see the photos but when are you going to post the renders? :arrow: :P
i7-3820 @4.3Ghz | 24gb | Win7pro-64
GTS 250 display + 2 x GTX 780 cuda| driver 331.65
Octane v1.55
kubo
perfection improved.... wow. ;)
gabrielefx
perfect work!
you reached the Cuda limits...64 textures
I have the same problems with many books
ribrahomedesign
thanks a lot guys .
kubo
gabriel, for that there is an easy solution, one I used for books actually. You just create a large "matrix" texture were you pack all the book's. For example if you have 9 different books you create a 3000x3000 texture and "divide" it in an imaginary 3x3 matrix were you place each book's texture. Then you assign this material to all the books and play a little with the uvmaps to assign to each its own, it's quite fast once you've done a couple, and once you are finish you have your own collection of several books only using a single texture, and hence freeing space for many other images.
gabrielefx
kubo wrote:gabriel, for that there is an easy solution, one I used for books actually. You just create a large "matrix" texture were you pack all the book's. For example if you have 9 different books you create a 3000x3000 texture and "divide" it in an imaginary 3x3 matrix were you place each book's texture. Then you assign this material to all the books and play a little with the uvmaps to assign to each its own, it's quite fast once you've done a couple, and once you are finish you have your own collection of several books only using a single texture, and hence freeing space for many other images.
I would like to have and automatic function to do this in Max...
kubo
well, actually there is, you can bake them all toghether in a single texture, it won't be as clean, but it'll be fast and easy.
