3dsmax standard lights
MaTtY631990
Hi
Will their be possibly any support for the 3dsmax standard lights such as omni and spot lights similar to what iray can do.
gabrielefx
MaTtY631990 wrote:Hi
point light in Max is a spherical light with radius zero
Spot light is a light that can be simulated creating a cylinder with an emitter inside
Btw I asked to Karba to add spherical and planar lights without create geometries and then assign materials+blackbody
This process could be done internally by the plugin. With light primitives we will have more controls in one ui panel: dimensions, temperature, color, samples, on-off switch, double side, skyportal, texture.
MaTtY631990
Thanks.
Return to “Autodesk 3Ds Max”
