octane not showing up as a choice to render with
p3taoctane
I placed the plugins in the path appropriate for my max version according to the directions
But Octane render is not available under the render tab in render settings.
Is there a way I can check to see if it is loaded in any way?
MaTtY631990
Did you make sure to put the Octane3dsmax.dlr in the correct directory. This needs to be in the 3dsmax plugin directory, just this file. All other files go into the root directory.
p3taoctane
yep sure did
even changed the name of the directory to Plugins instead of plugins in case that the issue
nope
MaTtY631990
What version of 3dsmax do you use.
p3taoctane
2012 very latest version.
MaTtY631990
Try to download the package again and reinstall them.
MaTtY631990
Did you copy the plugins folder containing the octane3dsmax.dlr file into the 3dsmax plugin directory or just the file inside.
p3taoctane
Just the file. I'll send screen captures later to see if I messed up
There are other plugins in that folder and Max sees them when I use the tools (hammer icon)
Return to “Autodesk 3Ds Max”
